SiR Crank Question
Old Aug 3, 2005 | 10:24 PM
CrxSiVtec83's Avatar
Default SiR Crank Question
Do the 1st gen SiR b16a and the 2nd gen SiR b16a cranks have the same specs? Are they interchangeable?
Thanks
Old Aug 4, 2005 | 12:11 AM
rjay8604's Avatar
Default Re: SiR Crank Question (CrxSiVtec83)
Yes, in fact all b-series cranks are interchangable in the block. I know its awesome isn't it.
Old Aug 4, 2005 | 03:08 AM
Garrett's Avatar
Default Re: SiR Crank Question (rjay8604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, in fact all b-series cranks are interchangable in the block. I know its awesome isn't it. </TD></TR></TABLE>
I think you need to study a Little bit more at Honda University
ALl B16A crank are interchangeable
B16B is unique
b18a/b-b20b/z are interchangeable
b18c are all interchangeable
Old Aug 4, 2005 | 03:11 AM
limpy's Avatar
Default Re: SiR Crank Question (Garrett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett &raquo;</TD></TR><TR><TD CLASS="quote">I think you need to study a Little bit more at Honda University
B16B is unique
b18c are all interchangeable </TD></TR></TABLE>
yes but you can put a b18a/b crank in a b18c block but not a b16a
Old Aug 4, 2005 | 03:31 AM
Garrett's Avatar
Default Re: SiR Crank Question (limpy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy &raquo;</TD></TR><TR><TD CLASS="quote">
yes but you can put a b18a/b crank in a b18c block but not a b16a</TD></TR></TABLE>
with some Machining work
Old Aug 4, 2005 | 09:27 PM
rjay8604's Avatar
B16B is unique
Well yeah i see what you mean, i just meant the bore spacing, journal width and diameters are all the same so the crank itself will work, but yes of course stuffing a 89mm b20/LS crank in a b16a would require some short rods or some radical compression height pistons.
cmaguire613
10
Apr 8, 2014 11:54 AM
VtecHachi
May 2, 2007 10:32 AM
JDM_EK4_Coupe
Jan 21, 2007 02:28 PM
b16si99
Feb 17, 2006 11:12 PM
