Tranny/Clutch issues - drag racing act 6pk quaife b16, input shaft bearing?
Old Aug 3, 2005 | 09:49 PM
dunkd's Avatar
Default Tranny/Clutch issues - drag racing act 6pk quaife b16, input shaft bearing?
After my burnout I pull out and I have very little clutch pedal pressure so i immediatly pull off the track and into the pits. I put the street tires back on and go for a spin. When starting from 0 mph it makes a bad grinding noise as I let out the clutch. Once I get going it shifts fine into all the other gears, drives like nothing is wrong. I had no other issues with clutch pressure. When I start from a roll in 1st gear the noise isn't there, its only from a stop.
The clutch is ACT 6pk with extreme pp. tranny is b16 with quaife lsd.
EDIT: tonight i took it out for the first drive since i got back from the track the other night and the noise is pretty much gone. Im guessing that something on the clutch or pressure plate is messed up and it might have slowly worn down. the clutch isn't slipping though. Also, the slave cylinder squeaks loud when pressing in the clutch now...
Modified by dunkd at 1:22 AM 8/6/2005
Old Aug 4, 2005 | 09:21 AM
dunkd's Avatar
bumppp
Old Aug 4, 2005 | 03:34 PM
Dan GSR's Avatar
Default Re: (dunkd)
too many things it could be
gotta open that sucker up
if you need trans work, i'm avail
Old Aug 4, 2005 | 06:41 PM
dunkd's Avatar
yah maybe ill take off the tranny and my clutch will just fall out... thats what im hoping atleast bc im def going to put in a new clutch while i have it apart... hopefully the tranny wont need work as well.
Old Aug 4, 2005 | 07:13 PM
dakidhasSOL's Avatar
well i doubt your clutch is the only prob, tell me how it turns out.
Old Aug 4, 2005 | 08:03 PM
v4lu3s's Avatar
RTFM
how long have you had the clutch?
Old Aug 4, 2005 | 08:10 PM
dunkd's Avatar
5k on it - 2k at this power level
Old Aug 5, 2005 | 05:18 AM
v4lu3s's Avatar
RTFM
i have a sort of grind type sound when my 6 puck is cold, and it only occurs when i start in first or reverse. after a few minutes it always goes away. its been like that since i got the clutch, and it also chatters mroe when teh clutch is cold too. i had always assumed it was normal since i have had other clutches that did it and after inspection i couldnt find a problem.
Old Aug 5, 2005 | 09:22 PM
dunkd's Avatar
Old Aug 6, 2005 | 11:20 AM
dunkd's Avatar
also, its almost impossible to avoid clutch chatter now when starting out.
EKJOE
Transmission & Drivetrain
Jun 2, 2009 07:38 PM
lurkin' eg
Jun 8, 2008 08:17 PM
got2
Jun 20, 2006 08:49 PM
B-B-K
Feb 9, 2005 09:25 PM
greensleeper
Jul 31, 2002 02:33 PM
