starting problem? need help
Old Aug 3, 2005 | 05:19 PM
stoned_sol's Avatar
Default starting problem? need help
my del sol has not been driven for a couple months because i have been doing body work on it. i would occasionally have to start it to move it out of the garage to do stuff, but it wouldn't ever start rite away. it would crank, but not turn over, after tying a couple times it would finally turn over. i figured the starter might just be going bad, but tonight i went to start it and on the second try in turned over but as soon as i gave it gas it bogged out and shut off. can i get some help on what the problem might be, i am planning on painting this weekend and i want to have it running.
Old Aug 3, 2005 | 06:59 PM
xEnderx's Avatar
Default Re: starting problem? need help (stoned_sol)
Sounds like it might be a fuel issue.
Old Aug 3, 2005 | 07:14 PM
BenzTek134's Avatar
check your feul pump relay its located under the driver side of dash area next to your hood release, sounds like the problem to me. good luck
Old Aug 4, 2005 | 03:15 AM
stoned_sol's Avatar
Default Re: starting problem? need help (BenzTek134)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BenzTek134 &raquo;</TD></TR><TR><TD CLASS="quote">check your feul pump relay its located under the driver side of dash area next to your hood release, sounds like the problem to me. good luck</TD></TR></TABLE>
i will check that this evening. it is definatly not getting fuel to the engine, i hope that fixes it. thanks
v6accordcoupejunkie
Sep 28, 2009 05:41 PM
bimmeracer
Feb 11, 2008 10:19 AM
D50boy
Acura TL, RL & ZDX
14
Aug 16, 2007 04:35 AM
oakpwr
Jan 20, 2007 12:05 PM
Gonzo_SiR
Mar 8, 2004 05:22 PM
