s80 tranny problems....
car goes into gear but i really have to play with it....but the gears dont grind...and i cant get into reverse .... any suggestions as to what may be the problem ive opened up the trans and can not find anything visibly broken inside...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Stance »</TD></TR><TR><TD CLASS="quote">no smell at all...for some reason i think its in the linkage.....so i changed them, but im still getting the same issue.... </TD></TR></TABLE>
check your pressure plate, check the piece that makes the shift forks move up and down. it's held be three 10mm screws, if that plate is bendt you'll have a hard time getting it in gear!
I am having the EXACT same issue. The tranny doedn't grind, but finding the gears is difficult, like the linkage isn't lining up. I figured the shift fork or something was bent inside the tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bitzbp »</TD></TR><TR><TD CLASS="quote">I am having the EXACT same issue. The tranny doedn't grind, but finding the gears is difficult, like the linkage isn't lining up. I figured the shift fork or something was bent inside the tranny.</TD></TR></TABLE>
you probably broke the plate on part #4, i had a friend that tore the screws that hold that piece down. he could only get the car to go into 5th gear, and he drove it home from the track(60+ miles away)
yup my first gear was hard to put into at times... i thought i had a bad pilot bearing. but i found it was the slider forlk want bad. i heard its due to resting your hand on the shifter while driving???
LERRY
16
Jan 12, 2007 05:50 PM
