Bleeding my brakes, one more question.
Old Aug 3, 2005 | 03:30 PM
Nocturnal's Avatar
Default Bleeding my brakes, one more question.
I'm going to be bleeding my brakes tomorrow. Should I get my car up on four jacks or can I just jack up the rear, do the passenger rear, put the tire back on, lower it. Jack up the front, do the driver front, bleed it, put the tire back on, lower it. Jack up the rear driver, etc etc.
Or should I have it jacked up on four jacks?
Old Aug 3, 2005 | 03:32 PM
ek4d00r's Avatar
Default Re: Bleeding my brakes, one more question. (Noct)
since youre supposed to repeat the bleeding process a few times, its probably less work overall to just have it on jackstands rather than takes wheels on and off
litterbox's Avatar
I am a (Trial User) Army
Have it jacked on all four corners. You go in a certain order. The order is:
Passenger Rear
Driver Front
Driver Rear
Passenger Front
Keep doing that order like a million times.
Old Aug 3, 2005 | 03:34 PM
Nocturnal's Avatar
I thought once each side would be enough?
Old Aug 3, 2005 | 03:36 PM
litterbox's Avatar
Default Re: (Noct)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noct &raquo;</TD></TR><TR><TD CLASS="quote">I thought once each side would be enough?</TD></TR></TABLE>No sir.
Lemme ask you, is there fluid in your MC, or is your entire system empty?
When I swap MC's, and my system is completely empty, I go through two bottles. Big bottles.
Old Aug 3, 2005 | 03:38 PM
Nocturnal's Avatar
It's full. I haven't taken all the fluid out yet. I'm going to do it tomorrow with a turkey basin.
Old Aug 3, 2005 | 03:41 PM
litterbox's Avatar
Default Re: (Noct)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noct &raquo;</TD></TR><TR><TD CLASS="quote">It's full. I haven't taken all the fluid out yet. I'm going to do it tomorrow with a turkey basin.</TD></TR></TABLE>So you're swapping MC's? You don't need to scoop up your old fluid, just bleed it alot and it'll run through the entire system and come out at the bleeder valves. IMO that's the best way, it ensures no air gets into the lines from the MC.
Old Aug 3, 2005 | 03:43 PM
Nocturnal's Avatar
No, I'm just bleeding my brakes because I disconnect the brake line to my rear calipers to change my brake pads.
Old Aug 3, 2005 | 03:45 PM
litterbox's Avatar
Default Re: (Noct)
Ok, but still, just bleed out your old fluid by bleeding the brakes and continuously adding in new fluid to the MC to keep it above the Low line.
Jjinta
Suspension & Brakes
Sep 17, 2006 11:16 AM
alex_s817
Jul 3, 2006 08:51 AM
SlowSOHC-T
18
Apr 8, 2006 10:02 AM
JDMISACULT2
12
Feb 26, 2006 02:54 PM
SuicideSlide
Jul 13, 2004 10:14 AM
