Gsr Brake Swap, Bleeding question...
Gsr brake swap....15/16 MC 40/40 Prop, and GSRs all around on my 92 cx....Bled front to back, but not getting any pressure really. WHats the order... can i bleed from the MC? any suggestions would be great
Re: Gsr Brake Swap, Bleeding question... (JDMISACULT2)
isn't it in an X fasion..in other words..dr-side front then pass-rear//pas-front then driver rear....making sure the MC is full...hope this helps
cute little bastard
Pretty sure you gotta do it from the calipers and each the furthest from the MC. So thats passenger rear, driver rear, passenger front, driver front. I think. someone confirm.
Re: Gsr Brake Swap, Bleeding question... (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">Pretty sure you gotta do it from the calipers and each the furthest from the MC. So thats passenger rear, driver rear, passenger front, driver front. I think. someone confirm.</TD></TR></TABLE>
ah there you go..kicks in and makes sense once you see it from someone else..lol
Remember to have someone watch the M/C to make sure you have enough flud and you don't suck in air.
TSPeed Factory
Re: Gsr Brake Swap, Bleeding question... (RTI)
just keep doing it. it may take a while. and be sure to close the valve so no air can get back into the system.
Re: Gsr Brake Swap, Bleeding question... (AzntaggeR)
ok so now the problem is we keep bleeding it...no air is coming out
but when we turn the car on there is no pressure! pedal falls right to the floor am i missing something?
THanks for all the help
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMISACULT2 »</TD></TR><TR><TD CLASS="quote">ok so now the problem is we keep bleeding it...no air is coming out
THanks for all the help</TD></TR></TABLE>
So there is a nice stream of fluid coming out?
Re: Gsr Brake Swap, Bleeding question... (SAVIOVEGA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SAVIOVEGA »</TD></TR><TR><TD CLASS="quote">Did you just recently swap out the MC. If so did you bench bleed it ?</TD></TR></TABLE>
bingo, the MC has air in it and they need to be bench bled.
alex_s817
07-03-2006 08:51 AM
JdmLub
04-25-2006 06:01 PM
