hesitating and bucking under throttle
This is driving me nuts, its a 94 ex. rotor/cap/coil.. nothing.. replaced the distributer still no help.I replaced the plugs and wires. that helped only about 10%, at first I thought it was fixed but it now only happens when the car is warmed up. whats left? dieing fuel pump? clogged injectors? motor has about 170k on it.
grammer nawzi
Re: hesitating and bucking under throttle (Boostage)
Did you think of changing the fuel filter? Also my car b16 was doing the same thing, ended up being the O2 sensor
grammer nawzi
Re: (hoffman4684)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoffman4684 »</TD></TR><TR><TD CLASS="quote">$10, maybe...</TD></TR></TABLE>
If you were being serious, where the hell do you get your 02 sensor? Most Honda dealers charge a little over $200 for them.
i had the same problem with my hatch and i replaced the plugs and wires and dizzy and then on the test drive around the block it drove great then the next day it started all over again...i changed the fuelfilter and my problem was solved....12.99 at autozone...and if its not a fuel filter its worth changing after 11 years of service
