Wierd Noise
Old Aug 3, 2005 | 01:44 PM
bpetruzzo's Avatar
Default Wierd Noise
I noticed my car making a weird noise a few days ago. It kind of sounds like something is rubbing up against the left rotor or something, but it only really happens when I turn left (even just the slightest bit to the left). Just in the past day or two, it started getting a little worse, and you can kind of hear it even when the car is going to the right.
Any ideas what it could be?
Old Aug 3, 2005 | 01:47 PM
philosofy1's Avatar
Default Re: Wierd Noise (bpetruzzo)
is it a clicking noise or a grinding/squelly noise?
Old Aug 3, 2005 | 01:53 PM
amej8's Avatar
did u try just taking the wheel off and looking for loose bolts, unaligned parts etc?
did u check nething at all on ur own before u posted
Old Aug 3, 2005 | 11:16 PM
bpetruzzo's Avatar
Default Re: Wierd Noise (amej8)
I don't have the means to get in there and look around at the moment. I did the best I could sticking my head in there, but I couldn't see anything that looked obviously out of place. I figure maybe someone could point me in the right direction for when I'm able to do that.
It's not a clicking, it sounds like a rubbing. A little bit like the noise it would make if the rotors were warped.
Old Aug 3, 2005 | 11:19 PM
dE.fUsEd's Avatar
take the wheel off and see if the metal around the rotor is bent in. When i put my new calipers on i somehow bent it in a bit and it would make a scraping noise when turning left.
if it is, just bend it out a lil bit.
Old Aug 4, 2005 | 12:26 AM
_Cyclone_'s Avatar
Default Re: Wierd Noise (dE.fUsEd)
Yeah, check the heatshield. Mine makes a noise when I turn hard, but I don't care.
Old Aug 4, 2005 | 12:36 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Wierd Noise (_Cyclone_)
Yea mine are all fucked up from taking everything apart so many times. Probably just bent dust sheilds.
Old Aug 4, 2005 | 01:52 AM
_Cyclone_'s Avatar
Default Re: Wierd Noise (JDM_Ej)
Heat shield/dust shield, same ****.
Old Aug 20, 2005 | 02:06 PM
bpetruzzo's Avatar
Ok, so I was finally able to pull the wheels off and investigate some, and there's nothing rubbing against the rotor or anything. And since the noise has become like a louder almost beat that changes speed with the speed of the car.
I'm starting to think it's the CV axle, but that's like a $250 gamble. Any ideas?
Old Aug 20, 2005 | 02:44 PM
j12paris's Avatar
Im pretty sure its your left side cv joint, very common amoung eg civics. Do you only hear the noise while applying the throttle during a turn? Try coasting through a turn, if you dont here the noise, but here it when you the apply the throttle, you need cv joints.
-bearer of bad news
Old Aug 20, 2005 | 02:50 PM
philosofy1's Avatar
Default Re: Wierd Noise (-juce-)
in his original post he said something sounded like it was rubbing, cv joint dont make a rubbing noise, they make a clicking noise!
Old Aug 20, 2005 | 02:54 PM
philosofy1's Avatar
as far as the noise goes, check your pads, sometimes they wear uneven, causing the metal on the worn pad to rub on the rotor.
Dackonn
Suspension & Brakes
37
Mar 2, 2025 02:16 PM
Forrest04
Honda CR-V & Element
Apr 16, 2014 11:50 AM
k20eklipse
Aug 3, 2010 08:40 PM
del sol1658
Jun 6, 2006 12:54 PM
DeregginOut
Jul 4, 2002 11:40 AM
