no vtec when hot...
Old Aug 3, 2005 | 12:16 PM
high_revs's Avatar
Default no vtec when hot...
so i been trying to diagnose this for a couple of days...started sunday night after a friendly street race and hitting a pretty decent bump.....anyways....after the car is fully warm and everything vtec will work for like 2-3 times then it will stop engaugeing and even at time it will be in vtec and just fall out...im thinking ots something with oil pressure but the light isnt on....ecu is good, the solenoid clicks, no check engine light.....i took a test light and hooked it up to the solenoid wire and at 4800 it lights up and lets me know juice is goin to the solenoid but there is no vtec...im running a virgen p28. no idea what to look for anymore. the oild pan has a minor dent but it has always been there and im running 10w40 oil....if any1 got any ideas please help.
Old Aug 3, 2005 | 12:28 PM
T-King's Avatar
Default Re: no vtec when hot... (all mOtor h23)
Is the vtec pressure switch and solenoid wired into the harness and then to the ecu or is it directly from pressure solenoid to ecu?
Old Aug 3, 2005 | 12:31 PM
high_revs's Avatar
they go driectly into the ecu....vtec worked fine for like 700 miles then it started acting up.
Old Aug 3, 2005 | 12:37 PM
T-King's Avatar
Default Re: (all mOtor h23)
ok because mine used to do that and I guess after a few really hard launches it like knocked the wires loose from the ecu, so I had to rewire it into the ecu. Maybe pull of the ecu cover and look at the wires and see if they are still connected properly.
Old Aug 3, 2005 | 12:42 PM
high_revs's Avatar
yeah i checked already and im getting a signal from the ecu to the solenoid at 4800 so that tells me that the wiring should all the good.
Old Aug 3, 2005 | 12:56 PM
britishlude's Avatar
Maybe you slightly dented your oil pan when you hit that bump, if the oil pickup tube is restricted at all, vtec can be totally cut off or works only now and again, as you need enough oil pressure.
Old Aug 3, 2005 | 12:58 PM
T-King's Avatar
Yea and you said you didnt have any CELs on, I had the code for the pressure switch and solenoid flashing. Damn well
Bump
Old Aug 3, 2005 | 12:59 PM
high_revs's Avatar
Default Re: no vtec when hot... (britishlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by britishlude &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you slightly dented your oil pan when you hit that bump, if the oil pickup tube is restricted at all, vtec can be totally cut off or works only now and again, as you need enough oil pressure.</TD></TR></TABLE>
yeah thats the only thing i can possibly think of, so today after work im dropping dat b*tch down and bangin it back straight, hopefully this will fix it, cuz it was good right before the bump.
Old Aug 3, 2005 | 01:40 PM
While the pan is off check the oil pick up tube real carefully, just to ensure it's not suffered a slight squashing.
Old Aug 3, 2005 | 01:50 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by britishlude &raquo;</TD></TR><TR><TD CLASS="quote">While the pan is off check the oil pick up tube real carefully, just to ensure it's not suffered a slight squashing.</TD></TR></TABLE>
yeah most deff
Old Aug 3, 2005 | 10:08 PM
high_revs's Avatar
so infact the crushed or dented oil pan was the cause of having no vtec....there was a mark on the inside of the pan where the oil pick up tube had touched, so i made it as perfect as possible and i have vtec all day
thanx a lot fellas.
5280dc2
Apr 6, 2008 07:53 AM
JDM-MONKEY
Jan 14, 2006 10:10 AM
sharkcohen
Mar 11, 2005 07:55 AM
AdamITR
Apr 17, 2003 03:00 PM
AdamITR
Apr 14, 2003 04:38 PM
