IPS K2 Dynojet Results: 234whp & 161ft/lbs
Old Aug 2, 2005 | 02:28 PM
schuessler28's Avatar
Default IPS K2 Dynojet Results: 234whp & 161ft/lbs
I spent about an hour on the dyno at Hybrid-Dynamics last friday morning. Most of my focus went into smoothing out the A/F. 80% of the map used for my final pull came from the IPS supplied basemap. Every IPS K2 dyno that I have seen has a convex rise from 5-6k. I uploaded the tuning map Jeff Evans did back in January with the K2s in my RSX(blowby on cyl #4). Suprisingly, it made decent power. So I took the areas where the Evans tune made more power and pasted all the data onto the IPS basemap to form a composite map. The VTEC point was lowered to 5300. Notice the concave rise from 5-6k now?
I'm very satisfied with the end result. I can't believe how linear the powerband is! This was my first time tuning. I might leave the ignition and cam angles to the pros.
IPS basemap(Blue) vs Evans-Tuning(Red)
Composite Map
Mods:
K20A2
PTR Velocity Stack
RBC manifold
IPS K2 camshafts
Toda headgasket
DTR 4-2-1 header
Kteller 3" exhaust
Last friday night, the car went 12.696@110.72mph with a 2.041 60' on BFG drag radials. Some guy let me borrow the BFGs and they were completely bald. I was hesitant to run them but more desperate for better traction.
Here is a shot of the engine bay. The hood barely closes with the RBC manifold.
Modified by schuessler28 at 11:40 PM 8/2/2005
Old Aug 2, 2005 | 02:46 PM
skunked's Avatar
Default Re: IPS K2 Dynojet Results: 234whp & 161ft/lbs (schuessler28)
nice mph....
What tranny are you running?
Old Aug 2, 2005 | 03:13 PM
Default Re: IPS K2 Dynojet Results: 234whp & 161ft/lbs (skunked)
K20A2 tranny with ATS 5.062 FD, Toda clutch/flywheel and Quaife LSD. I'm hittin 5th gear at the strip.
Old Aug 2, 2005 | 03:38 PM
THCk20eg's Avatar
nice.... did you happen to dyno before the k2s? if so what were the gains?
Old Aug 2, 2005 | 03:42 PM
Goatsterrman's Avatar
Default Re: IPS K2 Dynojet Results: 234whp & 161ft/lbs (THCk20eg)
Great Numbers....super nice power curve.
Old Aug 2, 2005 | 03:48 PM
Professor15's Avatar
Great numbers
Old Aug 2, 2005 | 03:58 PM
Unfortunately, I don't have any before dynos with this motor. I pulled these cams straight from my RSX and installed them on this engine before it even went into the car. And before I installed the K2s in the RSX, I had Toda N2s. And before that, Toda Spec As.lol So no baseline run. I could show you a N2 vs. K2 graph but that just seems to stir **** up.
Old Aug 2, 2005 | 04:11 PM
jdm_ef9's Avatar
very nice numbers mark!!!
car is very sick... and loud!
Old Aug 2, 2005 | 04:14 PM
THCk20eg's Avatar
cool. how much does your car weigh? and how do you like the tranny?
Old Aug 2, 2005 | 06:32 PM
Default Re: IPS K2 Dynojet Results: 234whp & 161ft/lbs (jdm_ef9)
Thanks Chris. I'm gonna try and get a muffler on it for next month.lol
THCk20eg, the tranny is fun as **** on the street. It'll roast 1st and 2nd with the LSD! I have no idea how much the car weighs but my estimate would be 2300lbs w/driver.
Old Aug 2, 2005 | 06:54 PM
THCk20eg's Avatar
yeah i know i ran the type r tranny for a while. roasted those bitches through 3rd with the 2.4l. thats a nice set up you got there, i wonder how much you would have made without the cams and manifold, they prob netted you some good power.
Old Aug 2, 2005 | 07:02 PM
EK Josh's Avatar
Old Aug 2, 2005 | 07:35 PM
six sigma racing's Avatar
Default Re: IPS K2 Dynojet Results: 234whp & 161ft/lbs (GGhatchie)
DTR POW WOW....
That powerband is FAT!
Honda4life777
Engine Management and Tuning
Jul 7, 2009 08:30 PM
adam00
Jan 26, 2009 09:19 PM
ProjectLSVTEG
Dec 4, 2005 07:11 PM
nab18
Nov 15, 2005 07:49 AM
