Crank Pulley Bolt
Old Feb 20, 2002 | 06:37 AM
JeffS's Avatar
Default Crank Pulley Bolt
Is the crank pulley bolt normal or reverse threaded?
I have a Helms, have consulted it, and don't see any mention of it being reverse threaded. I would love some confirmation of that before I break out the impact wrench though...
thanks
jeff
Old Feb 20, 2002 | 07:41 AM
Spade's Avatar
Default Re: Crank Pulley Bolt (JeffS)
Usually reverse tread bolts have notches in the middle of the sides on the corners....i.e. in the middle of the pointy part.
Edit: I sounds like a fricken third grader.
[Modified by Spade, 8:42 AM 2/20/2002]
Old Feb 20, 2002 | 08:04 AM
Crazydave's Avatar
Default Re: Crank Pulley Bolt (Spade)
This is normal thread
make sure to hit it with quick short blast with as much PSI in the tank as you can get.
[Modified by Crazydave, 9:04 AM 2/20/2002]
Old Feb 20, 2002 | 08:31 AM
FSTASNTZ's Avatar
Default Re: Crank Pulley Bolt (Crazydave)
Normal thread, and you will need an impact gun to get it off...
Jason
Old Feb 21, 2002 | 03:22 PM
3rdGteg's Avatar
Default Re: Crank Pulley Bolt (FSTASNTZ)
Once the bolt is off, how would you torque that bolt back to spec?-- Or do you just give it what your cheap impact gun can do in forward?
Old Feb 21, 2002 | 04:00 PM
Brian_92GSR's Avatar
New User
Default Re: Crank Pulley Bolt (3rdGteg)
You should use a torque wrench when putting it back on. I didn't have a good impact wrench when I had to take mine off a couple weeks ago. I was able to stick a strong bolt (I tried a screwdriver and it broke on me), through the flywheel to keep the crank from spinning. Then a 1/2" ratchet with a cheater bar got it off.
Old Feb 21, 2002 | 05:13 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Crank Pulley Bolt (Brian_92GSR)
That's exactly what I did. Jam a screwdriver into one of the flywheel holes and get a 19mm or 17mm (I forget which) ratchet with the end of my hydraulic jack handle and turned it HARD. It got off. Hehe. My 350ft-lb. impact gun didn't work...and my friend's 800ft-lb gun didn't work either.
Old Feb 21, 2002 | 08:00 PM
3rdGteg's Avatar
Default Re: Crank Pulley Bolt (shamoo)
How are you guys holding the flywheel still when torquing the bolt back on if it breaks screwdrivers?
Old Feb 21, 2002 | 09:20 PM
New User
After it broke a screwdriver I just found a bolt that fit through the hole.
Old Feb 22, 2002 | 07:57 AM
-TJ's Avatar
-TJ
Make a crank pulley holder.
Old Feb 22, 2002 | 08:19 AM
KF_S2000's Avatar
Default Re: Crank Pulley Bolt (-TJ)
Hey -TJ, what is the size of that nut you have welded onto the bar? I've been thinking of just making my own also. Thanks!
Old Feb 22, 2002 | 08:43 AM
-TJ's Avatar
-TJ
Default Re: Crank Pulley Bolt (kf_Type-R)
It's a 33mm nut - of course you're familier with the way metric fasteners are sized I hope....just go somewhere that sells a good variety of metric fasteners and ask for a 33mm nut. The thread pitch doesn't matter (1.5 or 2) because the measurement across the flats is the same (50mm). I'm not sure of the size of the hex broach on the R motor, but this is the closest size nut you can buy for the variety of pulley's I've got. Also, you might consider getting 2 nuts and welding them side by side if your pulley is anything like the B18C1 (the broach is deep in the pulley rather than right on the outside like the D16Z6 (etc.), B16A, B18A.
-TJ
Old Feb 22, 2002 | 03:51 PM
fixhondas's Avatar
Nice tool you got there T.
Old Feb 23, 2002 | 03:43 AM
absolutgsr's Avatar
ack... why is it that when there is a pic i actually want to see, i only get a red X?!?!
Old Feb 23, 2002 | 08:26 AM
bryant's Avatar
Default Re: Crank Pulley Bolt (DragonCTR69)
I think Sears might sell them. But if you make your own its a lot cheaper.
Old Feb 23, 2002 | 08:46 AM
-TJ's Avatar
-TJ
Default Re: Crank Pulley Bolt (CR-X)
Yeah....I made it. Sears was not involved in the inspiration, creation or design. If they make one similar, they ripped it off from me
It's a 33mm nut and an 18" long piece of 2" strap, 3/16" thick. The 33mm nut is large enough in the center (33mm for those of you not fastener savvy) for a 1/2" impact socket to fit through.
It works on 92+ D series crank pulley's and B series pulleys where the hex braoch is on the outer surface. I've got another nut to weld along side the one on there so that it will work with a B18C pulley (deep broach).
I've made a couple of other tools for holding the old D series pulleys with the holes around the outside too.
If you've got a lift, you can try to hold it with one hand while breaking the bolt loose with a 1/2" breaker bar. (I've never had to use an impact - didn't get a compressor until recently). It works better if the car is on jackstands - you can just let the handle rest on the floor and put all your effort into loosening the bolt.
Old Feb 23, 2002 | 10:22 AM
94civicx's Avatar
New User
I bought the moroso crankshaft pulley remover from summit racing for $70. tried impact guns and all the above with no luck before buying. I used the pulley remover with a jackstand to get it past the wheel well and a breaker bar to break it loose
Old Feb 27, 2002 | 08:37 PM
3rdGteg's Avatar
Default Re: Crank Pulley Bolt (94civicx)
Hey -TJ, can u get that picture of your tool to load up; I'd really like to see it but I'm just getting this red x where the picture's supposed to be. Thanks.
Old Feb 27, 2002 | 09:34 PM
ThePunk's Avatar
here is moroso's tool.
Old Feb 27, 2002 | 10:05 PM
tonyxcom's Avatar
Default Re: Crank Pulley Bolt (ThePunk)
moroso tool, used it loved it. worth every penny of 70 bux
Old Feb 28, 2002 | 05:26 AM
-TJ's Avatar
-TJ
Yeah, here it is from a different host.
Total cost, less than $5
[Modified by -TJ, 7:27 AM 2/28/2002]
[Modified by -TJ, 7:29 AM 2/28/2002]
Old Feb 28, 2002 | 09:14 AM
Crazydave's Avatar
dang.. thats a big tool!
Old Feb 28, 2002 | 09:49 AM
hensley's Avatar
We sell a fabricated crankbolt wrench similar to that in TJ's photo for $48.50 plus shipping
[Modified by hensley, 3:05 PM 2/28/2002]
Layne Barber
Apr 17, 2015 12:38 PM
barrera
Oct 11, 2010 07:17 AM
bandit080000
17
Jun 11, 2009 12:20 AM
legendboy
Nov 22, 2002 10:42 AM
