Installing Apexi Power FC in ODB1 Car
I need to figure out what all I need to install an Apexi Power FC on my B16A1 swapped CRX Si. I was thinking of "converting" to ODB1 via a new distributor and O2 sensor. Then use an ODB2b - ODB1 conversion harness to plug the Power FC box in to my stock CRX Si harness.
Will this work? Or do I need yet another ODB0 to ODB1 conversion harness that converts my stock CRX Si wiring to a plug that would be compatible with the ODB2b - ODB1 harness. Or can I skip all of that and get a ODB2b to ODB0 harness.
You need and OBD0 to OBD2A JDM conversion harness, OBD1 or 2 ECU and 4-wire O2 sensor.
We build the harness -> http://www.boomslang.us/custom.htm
Phoenix1
Aug 22, 2006 01:08 PM
CRseXy
Dec 27, 2004 05:36 PM
