updated: help.. anyone knows AEM cold intake 21-412 (integra type-r 97-01) can be used to 94-01 LS
Jul 30, 2005
I have 21-412 (integra type-r 97-01) AEM cold air intake, can I install it to my 95 LS B18B1?
It seems that is ok, but actually I know for LS part should be no. 21-403
HELP!!!!!
Aug 1, 2005
I have already installed type-r intake to LS integra, It's ok but this is not prefect fit.
the pipe is a little bit shorter than original LS aem cold intake(21-403). so the pipe is too closed with engine manifold and distributor and also the filter is too closed with the wheel's fender inner.
I decide to move out and sold it (very lucky), and already bought a used intake 21-403, it helps me to know what's big difference with 21-412 and 21-403.
*** one guy ask me that it is correct : the ITR AEM intake will fit the LS motor. you might wanna get urself a tappered couplin since the intake is a 3" and standard LS is 2 1/4. BTW all stock B series intake manifold t/b sit the same height ***
In my opinion, every style intake if you buy a used, please make sure the model number first and it is better with no modification work for installation.
finally, I don't know how to post the pics so I can't let you know what's difference.
Thanks for the professional information.
HELP!!!!!
Aug 1, 2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkycgo »</TD></TR><TR><TD CLASS="quote">BTW all stock B series intake manifold t/b sit the same height</TD></TR></TABLE>
no. GSR's are in a much different location because the t/b sits lower thanks to the dual-plan intake manifold that comes stock on those. also, as you have just found out the hard way, the ITR, LS, and B16 t/b's do not sit in the exact same spots, which is why your ITR intake didn't fit the LS very well. it fit on there, but the fit wasn't very good, because they are a bit off. same will go for B16 mixing with ITR or LS. but a GSR intake just won't work on any of these, at least it won't work well at all, and LS, ITR, or B16 intakes won't fit well at all on a GSR if you manage to stuff it in there.
you know, just as a sidenote. sorry about your intake mishap.
tkycgo
Aug 1, 2005 02:22 PM
