Problem with 95 integra
Old Aug 8, 2005 | 10:22 AM
rob_honda's Avatar
Default Problem with 95 integra
I have a 95 ls coupe and was wondering my maintainece required light and abs light came on how can i fix this. Nothing is wrong the car just want to know how to make the lights go off.
Old Aug 8, 2005 | 10:29 AM
gsr dood's Avatar
Default Re: Problem with 95 integra (rob_honda)
search man. feel ur hand on the panel under the steering wheel. onn the other side of the panel on the right side at the bottom theres a black box with a button. stick ur head under the dash and youll see it is a square button hold the button turn the ignition on and then off and then let go of the button and bam! its off. next time search
Old Aug 8, 2005 | 01:21 PM
bottlefed13's Avatar
Default Re: Problem with 95 integra (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">search man. feel ur hand on the panel under the steering wheel. onn the other side of the panel on the right side at the bottom theres a black box with a button. stick ur head under the dash and youll see it is a square button hold the button turn the ignition on and then off and then let go of the button and bam! its off. next time search</TD></TR></TABLE>
usually when my abs light goes on, it's just warning me that the abs reservoir is running low on fluid. i just fill it up, let it idle and it shuts off.
Old Aug 8, 2005 | 02:28 PM
projectTeG's Avatar
fix the problem, pull the code and see what it is
Old Aug 8, 2005 | 04:02 PM
modifyORdie's Avatar
your maintenance required light comes on every 6,000 miles or so to tell you to change your oil..just hit the button under the dash
Old Aug 8, 2005 | 08:32 PM
gsr dood's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">fix the problem, pull the code and see what it is</TD></TR></TABLE>
what are you talkin about? matience light comes on every 6000 miles to warn the kid to bring the car in for matienece. theres nothing wrong with your car. dont bee scurrrred
Old Aug 9, 2005 | 10:07 AM
projectTeG's Avatar
Default Re: (gsr dood)
what are you talkin about? matience light comes on every 6000 miles to warn the kid to bring the car in for matienece. theres nothing wrong with your car. dont bee scurrrred</TD></TR></TABLE>
in a 95?
Old Aug 9, 2005 | 10:15 AM
Sic's Avatar
Sic
the maintence require light not the check engine. as said before theres a button under the steering coluom just push and its off
Old Aug 9, 2005 | 02:17 PM
jay_c's Avatar
Default Re: (Sic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sic &raquo;</TD></TR><TR><TD CLASS="quote">the maintence require light not the check engine. as said before theres a button under the steering coluom just push and its off</TD></TR></TABLE>
True, but the abs light will still store a malfunction code. Diag is necessary.
vteck1ck
Nov 15, 2008 02:33 PM
martyball619
Jun 1, 2007 05:23 PM
Rpizzle
Apr 13, 2005 09:09 PM
b18sol
Oct 23, 2003 05:31 AM
NtegraRacR05
Oct 5, 2003 07:15 AM
