Would it be better for performance if...........
Old Jul 28, 2002 | 01:57 PM
aCuRaLsTuRbO's Avatar
Default Would it be better for performance if...........
I put a AEM CAI for a TYPE R, on my LS? Would there be any more gains over the AEM CAI made for the LS? People put the OEM INTAKE off the TYPE R on the LS, so why not the AEM one? ANy input would be great...THANKS!
Old Jul 28, 2002 | 01:59 PM
rubens's Avatar
Default Re: Would it be better for performance if........... (aCuRaLsTuRbO)
If you look at the model number, regardless of if you have an LS or an ITR, you are getting the same intake.
Old Jul 28, 2002 | 02:00 PM
Default Re: Would it be better for performance if........... (rubenswm)
holy ****, i didn't know that...hmmm, i thought the diameter was larger on the TYPE R's ?
Mr. Softee's Avatar
neg. ITR intake has larger diameter, its 3". Ls is 2.5". I can personally vouch for this.
You'd gain top end, but lose low end with the ITR intake vs. teh LS intake.
Old Jul 28, 2002 | 07:04 PM
neo1z's Avatar
Default Re: Would it be better for performance if........... (94goldjungsr)
why would anyone waste their timing putting a stock itr intake on an ls...
Old Jul 28, 2002 | 07:15 PM
Default Re: Would it be better for performance if........... (neo1z)
uhh.....to gain top end i suppose...anyone else?
Old Jul 28, 2002 | 07:47 PM
96IntegraRS's Avatar
The difference between the R and the RS/LS is that the R draws air from the fender, not the engine compartment.
There is absolutely no difference in putting the R intake on versus the RS/LS intake. Buy whatever is cheaper. Any time you can introduce colder air into the mix, you're better off.
You have ABS, right? I don't; I have a 3 inch tube right from my throttle body to the hole in the fender, then to a K&N mounted inside the fender, using the stock 90 degree plastic tube. Tight setup.
G2Integrity's Avatar
Intakes are tuned to make the most power for their application. The 2.5" diameter for the LS takes better advantage of its good torque curve.
Old Jul 29, 2002 | 01:04 AM
Default Re: Would it be better for performance if........... (G2Integrity)
yea i guess ur right...hmmm
IggyBcool
Feb 6, 2005 05:37 PM
Dels98R
Jun 15, 2003 02:45 PM
aCuRaLsTuRbO
Jul 23, 2002 07:33 AM
Project X
Jul 19, 2002 10:58 PM
integra2000
Sep 6, 2001 02:07 AM
