ls vtec with a pr4 ecu with a msd rpm activated switch for vtec
Old Aug 1, 2005 | 07:56 PM
redlseg's Avatar
Default ls vtec with a pr4 ecu with a msd rpm activated switch for vtec
is it the same as a p28 performance wise? or would the p28 performe better?
Old Aug 1, 2005 | 08:50 PM
redlseg's Avatar
Default Re: ls vtec with a pr4 ecu with a msd rpm activated switch for vtec (redlseg)
Old Aug 1, 2005 | 09:08 PM
chris_m's Avatar
* B A N N E D *
thats freakin ghetto and so is a stock p28 those are things people did 7 years ago things have changed
Old Aug 1, 2005 | 09:12 PM
redlseg's Avatar
Default Re: ls vtec with a pr4 ecu with a msd rpm activated switch for vtec (Christopher M)
"thats freakin ghetto and so is a stock p28 those are things people did 7 years ago things have changed"
i just bought my crx with a ls vtec and the guy had a ls ecu hooked up with the msd rpm activated switch for the vtec. what do u suggest i do? and whats wrong with a p28?
Old Aug 1, 2005 | 09:13 PM
redlseg's Avatar
Old Aug 2, 2005 | 05:37 AM
redlseg's Avatar
nobody knows?????????????
Old Aug 2, 2005 | 05:45 AM
GOLDBERG's Avatar
get a chipped p28, not a stock p28...
Old Aug 2, 2005 | 07:10 AM
boosted k20's Avatar
Default Re: ls vtec with a pr4 ecu with a msd rpm activated switch for vtec (GOLDBERG)
on a VTEC ecu, there are two separate fuel and ignition maps. one for the nonvetc part and one for when VTEC kicks in. when VTEC is on, the car puts more fuel and more timing into the motor. the LS ecu only has one set of fuel and ignition maps so u risk the chance of running lean.
just buy a P28 ecu and have it chipped with a GSR prpgram or have someone make and tune an uberdata chip for u. u will most likely need to run wires from the ecu to the engine for the vtec solenoid and VTEC pressure switch, since ur friend ghetto'd his ls-v setup
baulum
Engine Management and Tuning
Feb 16, 2020 08:48 PM
crip
Aug 16, 2010 01:47 PM
Addicted2Racing
10
Jan 27, 2004 04:29 PM
Homer_Simpson
Sep 29, 2001 05:01 AM
