torque loss w/ CRVtec?
Old Aug 1, 2005 | 07:24 PM
Gunmetal_B20_Hatch's Avatar
Default torque loss w/ CRVtec?
If you put a b16 head on a stock b20Z bottom end, will you lose alot of low end torque associated with the non vtec camshafts? could some one please post a dyno graph of a near stock CRVtec ?
Old Aug 1, 2005 | 07:33 PM
PogKai's Avatar
I think it's the other way.. more power from low to high end.
Old Aug 2, 2005 | 05:59 PM
JDMB16A4ME's Avatar
Default Re: torque loss w/ CRVtec? (Gunmetal_B20_Hatch)
the b16 vtec heads have higher airflow rates than the b20 head or any non vtec b-series head for that matter. i think pretty much the whole power band will be improved by the b16 vtec head, and it should give you heller top end too. if you do a crvtec then think
about some ctr or itr cams too, theyll really make the top end **** and get.
Old Aug 2, 2005 | 06:42 PM
Hapexamendios's Avatar
Default Re: torque loss w/ CRVtec? (JDMB16A4ME)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB16A4ME &raquo;</TD></TR><TR><TD CLASS="quote">the b16 vtec heads have higher airflow rates than the b20 head or any non vtec b-series head for that matter. i think pretty much the whole power band will be improved by the b16 vtec head, and it should give you heller top end too. if you do a crvtec then think
about some ctr or itr cams too, theyll really make the top end **** and get.</TD></TR></TABLE> i would imagine that you would need higher compression pistons for type r cams
robit50
Aug 1, 2010 09:06 PM
parfait2882
Dec 12, 2006 03:05 PM
SpankyofNOLA
13
May 7, 2005 01:27 PM
B16-EF
Apr 29, 2005 06:08 PM
xplosivelikec4
May 31, 2004 07:33 AM
