rev 9k??
Old Aug 1, 2005 | 05:08 PM
sdr KEL's Avatar
Default rev 9k??
**DELETE**
Modified by sdr KEL at 4:32 PM 6/6/2008
Old Aug 1, 2005 | 05:17 PM
RedEj8's Avatar
Default Re: rev 9k?? (eg racer)
I assume ur talking about revving to 9 on your b20...Well u should probably get arp rod bolts and u need to get dual springs and retainers.
Old Aug 1, 2005 | 05:21 PM
sdr KEL's Avatar
what kind of dual springs n retainer would u prefer??
Old Aug 1, 2005 | 05:24 PM
RedEj8's Avatar
Default Re: (eg racer)
i dunno how much money u wanna spend? portflow, rocket motorsports,blox, skunk2, omni power all make good springs and retainers.
Old Aug 1, 2005 | 05:29 PM
sdr KEL's Avatar
does camshaft n gears will help reving also?? or juss rods,retainers,n springs?
Old Aug 1, 2005 | 05:35 PM
RedEj8's Avatar
Camshafts control how much hp u make and cam gears just let u tune the camshafts to make more hp, they dont have anything to do with the rev limit. Theres really no point in having a 9k redline without getting some cams that will make power that high.
Old Aug 1, 2005 | 05:36 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (reddohcvtec)
To infinity and beyond...........................
Old Aug 1, 2005 | 05:47 PM
xEnderx's Avatar
Default Re: (goforbroke)
Hukt on foniks wurkt fer mee.
Old Aug 1, 2005 | 05:57 PM
jdmHboy's Avatar
Default Re: (xEnderx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">Hukt on foniks wurkt fer mee.
lol
Old Aug 1, 2005 | 06:05 PM
noboostedEGo's Avatar
Default Re: (jdmHboy)
What about the bottom end other than the rod bolts, such as balance the rotating assembly, etc. Is that irrelevant?
Old Aug 1, 2005 | 06:11 PM
RedEj8's Avatar
Default Re: (noboostedEGo)
Honda motors are suppossed to be pretty well balanced from the factory
Old Aug 1, 2005 | 06:22 PM
xEnderx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec &raquo;</TD></TR><TR><TD CLASS="quote">Honda motors are suppossed to be pretty well balanced from the factory</TD></TR></TABLE>
They are.
Old Aug 1, 2005 | 09:40 PM
So a b20 or ls bottom end you think would be balanced enough for safe, durable revving to 9k w/proper valvetrain setup? If so that's pretty damn sweet.
Old Aug 1, 2005 | 10:24 PM
RedEj8's Avatar
Itd be safe if u got some arp rod bolts to go with it.
Old Aug 1, 2005 | 10:31 PM
Rocket's Avatar
Some profiles can make power higher into the rpm ranges than others. Skunk Stage 3 and M22 Profiles come to mind
Old Aug 1, 2005 | 10:43 PM
RudeBwaiSi's Avatar
Revving a stock B20 bottom can cause the sleeves to crack, and lessen piston life. I would suggest sleeving block as an option for high 9k revs on B20.
Old Aug 3, 2005 | 01:45 AM
civicstar's Avatar
Default Re: (RudeBwaiSi)
resleeve, girdle, headwork, new retainers, new valve springs, chipped ecu,
BrakeDanceJ
Oct 5, 2007 05:49 PM
97turboteg
Jan 5, 2006 11:11 AM
persianprelude
Mar 31, 2004 10:11 AM
xsnrgsr
17
Aug 14, 2003 06:44 AM
Dancing is Forbidden
Apr 27, 2003 09:30 AM
