ok so whos runnin 11's on stock sleeves with a ls-turbo?
Old Aug 1, 2005 | 04:58 PM
.adam.'s Avatar
Default ok so whos runnin 11's on stock sleeves with a ls-turbo?
im just wonderin how many of you guys are runnin 11's on stock sleeves? im planning on building an ls-t hatch and am trying to see some different setups. also please specify if this is a dd or just a track car.
Old Aug 2, 2005 | 12:16 AM
kazino42's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (civicskater)
Check my sig. DD
Old Aug 2, 2005 | 01:21 AM
ninesecrx's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (kazino42)
I knew this one hommie that did it once and his hommie said it was tru.
Old Aug 2, 2005 | 02:31 AM
b20turboic's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (ninesecrx)
my friend has a cx hatch with stock ls motor with a pieced kit. Inline pro mani , 60-1 , 3 inch dp , ect ect ect... He runs 11.8 all day. Only made 262 whp tooo
Old Aug 2, 2005 | 05:08 AM
quicksol95's Avatar
it can be done
Old Aug 2, 2005 | 10:00 AM
amit's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (darkwingduck81)
there was a guy on here ran a 11'7 with a greddy 18g on SAFC , forget his username.
Old Aug 2, 2005 | 11:07 AM
fmfkid250's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (b20turboic)
thats me, bone stock ls motor out of a 1990 4 door with 170k, with 94 cams
and a 60-1
10 psi is all it takes!
Old Aug 2, 2005 | 12:39 PM
99lspwr's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (amit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amit &raquo;</TD></TR><TR><TD CLASS="quote">there was a guy on here ran a 11'7 with a greddy 18g on SAFC , forget his username.</TD></TR></TABLE>
I will take the credit for that please.....thank you
See my sig. for exact et & mph...
Old Aug 2, 2005 | 01:23 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkwingduck81 &raquo;</TD></TR><TR><TD CLASS="quote">it can be done </TD></TR></TABLE>
Very easily <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr &raquo;</TD></TR><TR><TD CLASS="quote">
See my sig. for exact et & mph...</TD></TR></TABLE>
That's the hot ****!
Old Aug 2, 2005 | 01:35 PM
99lspwr's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Very easily
That's the hot ****! </TD></TR></TABLE>
HAHA !! Whats up man, you know I gotta take the credit for all my ganksta *** toonin !!!!
Old Aug 2, 2005 | 01:42 PM
xfrankx's Avatar
fmfkid250 on here is. bone stock ls motor with a peiced together turbo kit went 11.8 on bfg's
EDIT: just saw that he already replied haha. well ive seen it happen so its def possible. just get it tuned well
Old Aug 2, 2005 | 06:48 PM
ARR GEE's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (xfrankx)
What tranny are you guys using? Are you staying w' the LS tranny?
Old Aug 2, 2005 | 07:07 PM
playboyace35's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (ARR GEE)
im guessing they are using the gsr tranny...
i'll let ya know what i hit tomorrow at the track
stock b18b1 w gsr tranny
dsm 450s
hondata
t3/t4 .57 trim @ 10 psi
Old Aug 2, 2005 | 07:10 PM
tommyten's Avatar
I dont know if it this counts but Jim Hucks ran 11.8 this weekend with a stock b20 block on drag radials
Modified by tommyten@fast-turbo.com at 8:43 AM 8/3/2005
Old Aug 2, 2005 | 07:27 PM
dsm 450s
hondata
t3/t4 .57 trim
Old Aug 3, 2005 | 01:07 AM
krispyone's Avatar
ran a 12.2 with my LS/vtec
Old Aug 3, 2005 | 02:16 AM
hondaguyef's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (99lspwr)
HAHA !! Whats up man, you know I gotta take the credit for all my ganksta *** toonin !!!! </TD></TR></TABLE>
I'll hand it to ya, I've never seen results like you had on the AFC and BTM.
Here is a thread: CLICK HERE , I watched that car do mid 11 sec. passes on the stock longblock for an entire year and then he sold the car to another buddy of ours and it still was in the 12's on DR's. They just recently pulled the motor out. It had an LS tranny on it.
Phil
Old Aug 3, 2005 | 04:40 AM
nsxmatt's Avatar
You stock sleeve foolz!
Old Aug 3, 2005 | 11:18 AM
99lspwr's Avatar
Default Re: ok so whos runnin 11's on stock sleeves with a ls-turbo? (playboyace35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playboyace35 &raquo;</TD></TR><TR><TD CLASS="quote">im guessing they are using the gsr tranny...
dsm 450s
hondata
t3/t4 .57 trim
I was using the ls tranny w/ my setup...I still dont know how anyone can use a shorter geared tranny with an ls-t setup...I was at the rev limiter in 4th gear using a 24" tall tire.....And that was at 118-120 mph range....
Old Aug 3, 2005 | 11:23 AM
99lspwr's Avatar
[QUOTE=hondaguyef]
It actually never blew up either....It was a 160k + mile motor with about 150 passes and I never had any trouble with it at all.... Not the optimun set-up as we all know, but sure as hell worked for a good while..
dragsol
Sep 6, 2007 07:30 AM
93lsd
Jan 1, 2004 11:46 AM
weakGOODJunKieS.com
Apr 8, 2003 06:40 AM
