What dizzy for obd-1 ls/vtec
Old Aug 1, 2005 | 09:51 AM
Ekay Jay's Avatar
Default What dizzy for obd-1 ls/vtec
Just got my ls/vtec put into my DA and it wouldnt start(not getting any fire). There is power going into the dizzy but nothing coming out. Im using my old obd-1 ls dizzy(worked fine when i pulled the engine. I had to cut a leg off to put it on, so now i want to get a new obd-1 dizzy that will bolt right on to see if it is my dizzy. Which dizzy will work and have the same bolt pattern? I tried a 93 integra 1.7 but it was the same bolt pattern as my ls. Any help would be great!!
Old Aug 1, 2005 | 09:58 AM
sleepycivichb's Avatar
Default Re: What dizzy for obd-1 ls/vtec (JdM DA InTeGrA)
http://www.streetimports.com/p...d=688
I own one myself and it's awesome and cheapest price around.
Old Aug 1, 2005 | 10:08 AM
Ekay Jay's Avatar
So i need a dizzy for a 94 gsr right?
Old Aug 1, 2005 | 01:44 PM
ALLMOTA92EG's Avatar
you can use the ls dizzy but you have to modify it so it wont hit the vtec soliniod
Old Aug 1, 2005 | 01:54 PM
Ekay Jay's Avatar
Default Re: (jdm92civichb)
Yes i know that, already have a ls dizzy with a cut leg. I want an ond-1 dizzy that will bolt right up.
Old Aug 1, 2005 | 06:11 PM
Honda Sport's Avatar
coil or ignitor might be bad. you should run some tests to see if they are bad. should be a lot cheaper to buy a coil or ignitor. the dizzy you should get all depends on the VTEC head you used. ex; 94-95 gsr head, use a 94-95 gsr dizzy.
Old Aug 2, 2005 | 04:00 AM
Ekay Jay's Avatar
Default Re: (Honda Sport)
Just bought a new dizzy and im still not getting any spark, so it not my dizzy....
Old Aug 2, 2005 | 07:23 AM
if power is getting to your dizzy and it's still not sparking, I say check your spark plug wires for resistance.
Old Aug 2, 2005 | 08:08 AM
Ekay Jay's Avatar
I checked the spark plug wires also, still no fire.
Modified by JdM DA InTeGrA at 11:59 AM 8/2/2005
Old Aug 2, 2005 | 08:25 AM
91civicDXdude's Avatar
check the thermostat housing ground
Old Aug 2, 2005 | 08:58 AM
Ekay Jay's Avatar
Default Re: (91civicDXdude)
Its hooked up....
Old Aug 2, 2005 | 10:42 PM
I say replace the spark plug wires with new ones or ones you know are working. since power is going to the dizzy, the problem has to be from the dizzy on but since you have a new dizzy, it has to be passed the dizzy. last component to the spark plugs is the wires...
Old Aug 2, 2005 | 11:35 PM
rjay8604's Avatar
Check all grounds, battery to chassis, battery to tranny and engine, chassis to valve cover and chassis to cylinder head. Any check engine lights? Wiring issue. Ignitor (wht wire) signal gettin to Dizzy? hmm good luck. I know this kinda stuff isn't any fun.
Old Aug 3, 2005 | 01:13 AM
MenaceL.A.671's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">coil or ignitor might be bad. you should run some tests to see if they are bad. should be a lot cheaper to buy a coil or ignitor. the dizzy you should get all depends on the VTEC head you used. ex; 94-95 gsr head, use a 94-95 gsr dizzy.</TD></TR></TABLE>
Old Aug 3, 2005 | 06:47 AM
Ekay Jay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">I say replace the spark plug wires with new ones or ones you know are working. since power is going to the dizzy, the problem has to be from the dizzy on but since you have a new dizzy, it has to be passed the dizzy. last component to the spark plugs is the wires...</TD></TR></TABLE>
Its not the wires, i already tried that. All my grounds are hooked up.
Old Aug 3, 2005 | 06:49 AM
Ekay Jay's Avatar
Default Re: (m2slsvtec)
As far as the coil or ignitor goes, i have a brand new dizzy. I have a new chipped p28 w/ITR base map that i ordered from Kenji. U guys think maybe something happend with the ECU? Chip error or something??
Old Aug 3, 2005 | 06:40 PM
Ekay Jay's Avatar
Default Re: (JdM DA InTeGrA)
ttt
Old Nov 1, 2005 | 08:18 PM
slixxracing's Avatar
Did you check your timing? It might be off thats why you're not getting any sparks.
Old Nov 2, 2005 | 03:54 AM
Ekay Jay's Avatar
Default Re: (slixxracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slixxracing &raquo;</TD></TR><TR><TD CLASS="quote">Did you check your timing? It might be off thats why you're not getting any sparks. </TD></TR></TABLE>
sry but your about 3 months too late. problem was already fixed.
brandonschmidt
Dec 5, 2009 09:56 AM
Sic_DA_Nine
Apr 12, 2008 09:02 AM
vestalfootball72
Northeast (Sales)
Jul 14, 2007 04:05 AM
benjamin
Sep 6, 2004 10:08 PM
