Yikes, Alarm Fluttering, Colperate stuck Brake Lights
Old Jul 31, 2005 | 10:53 PM
TurboTeG4's Avatar
Default Yikes, Alarm Fluttering, Colperate stuck Brake Lights
Well tonight my Python 880xp start fluttering making mad clicking noises and couldnt be turned off, even with the battery disconnected??? So I put on the battery charger then the alarm went off so I turned it off. Ends up looks like my brake lights are stuck on, could the brake switch most likely be the problem(under brake pedal)???Also does my alarm have a backup battery or something since it wouldnt shut up even with the ground disconnected??????
Old Jul 31, 2005 | 11:33 PM
TurboTeG4's Avatar
Default Re: Yikes, Alarm Fluttering, Colperate stuck Brake Lights (TurboTeG4)
It was the plastic peice on the brake its broken
http://www.acuraoemparts.com/d...ch=no
Is that number 22 for the plastic peice that holds the switch IN?????
https://honda-tech.com/zerothread?id=1256922
Modified by TurboTeG4 at 8:47 AM 8/1/2005
RanCRX
Jun 9, 2008 07:35 PM
Kalokohan
Jul 14, 2006 10:50 AM
96Civic_Coupe
25
Apr 12, 2006 01:06 PM
dvp95
May 28, 2005 11:08 AM
TurBoXBirD16
Audio / Security / Video
Sep 10, 2002 01:02 PM
