Parking Brake Lights/
Old Sep 7, 2002 | 09:59 AM
TurBoXBirD16's Avatar
Default Parking Brake Lights/
I am trying to hook up my starter/alarm
i can't seem to find the parking LIGHTS wire...
i am not sure what the alarm wants.... does it want 12 V when the parking brake is ON?? or when it's off??
coz i think honda, when the parking light is ON, it won't have 12 V, when it's OFF, there is 12 V
what usually does other alarm do??
Please help
thanks
Old Sep 7, 2002 | 03:53 PM
philly-O's Avatar
Default Re: Parking Brake Lights/ (xbird)
you can get the brake wire at the brake switch (just above the pedal), and there is a plug-in terminal on the fuse blosk you can use for the parking lights. it is just to the right of center (i think it is the third from the right). but you use a speaker connector to slide it right on. they both test as voltage.
Old Sep 7, 2002 | 04:18 PM
Default Re: Parking Brake Lights/ (peichie)
i am talking about Parking Brake Light
Hand Brake Light
E brake Light
The starter won't start unless the parking brake is pulled
thanks anyways
Old Sep 7, 2002 | 08:06 PM
audioroach's Avatar
what you want to do is go to the hand brake ( park brake)....on its base is a switch...that will throw a ground when the brake is set...that is the wire to use.
Hope this helps.
PS on many systems its a ground..that it looks for on that wire.
[Modified by audioroach, 11:07 PM 9/7/2002]
Old Sep 7, 2002 | 08:11 PM
Default Re: Parking Brake Lights/ (audioroach)
no
it wants the parking light
not the parking signal...
i want a 12 V
Old Sep 7, 2002 | 08:51 PM
Default Re: Parking Brake Lights/ (EVIL Teken)
nonono hehehehe
The starter NEEDS the 12 V power from the parking light
so when the parking light is ON, the car can be started
u know what i am saying??
but now, the problem is....
I don't know what the starter wants
Does it want the 12 V when the parking brake is ON?? or when it's OFF??
I want to see how other starter works...then maybe mine works the same as others
One again, it's NOT the brake light i want
Old Sep 7, 2002 | 11:28 PM
well.. looks like my unit is a cheap *** ****
i am just using it as an alarm and door lock open then.....
let me run out every monring heheheh
thanks teken
You are the man !
Old Sep 10, 2002 | 01:02 PM
HandCommand's Avatar
You didnt list your car, so I will assume its a HONDA. On most Hondas the parking LIGHT circuit is Red with Black stripe. It will show ground at rest and 12V when turned on. While testing, spin the dimmer switch to make sure the voltage does NOT vary, if it does, you have mistakenly found the DIMMER circuit, not true Parking Lights.
As for PARKING BRAKE......most Hondas show GROUND when the Parking Brake is activated. It will show 12V at rest. Most will only show 12V at rest when the key is in the ON position. I usually test for the wire with the key in the ON position. To keep the install clean and tidy, I usually find the wires underneath the dash, but if you cant seem to find it, you could always go straight to the E-brake handle.
GOOD LUCK!!
eTiLiKo
Aug 9, 2018 03:03 PM
RanCRX
Jun 9, 2008 07:35 PM
96Civic_Coupe
25
Apr 12, 2006 01:06 PM
dungsta
Dec 2, 2005 07:52 PM
