quick noob wastegate question???
Old Jul 31, 2005 | 03:47 PM
theo99gsr's Avatar
Default quick noob wastegate question???
when using an external wastegate like a tial 38mm and an electronic boost controller is the lowest possible boost setting the setting of the wastegate spring???
for example if i had a .8 bar(aprox. 12psi) is that the lowest boost pressure i could run?
thanks.
Old Jul 31, 2005 | 04:22 PM
Tooned's Avatar
Default Re: quick noob wastegate question??? (theo99gsr)
Yes if u had a 12psi spring that would be your lowest boost setting u can go. Then will need a boost controller to turn it up.
Old Aug 1, 2005 | 09:11 AM
theo99gsr's Avatar
thats sucks. anybody got a new 6 or 7 psi spring they want to traid for a new 11.6 psi spring?
vg7z
Sep 20, 2006 08:27 PM
zbower7
Feb 6, 2004 09:48 AM
01ITR#700
Jun 22, 2003 10:01 AM
Dancing is Forbidden
Feb 16, 2003 08:42 AM
shingles
Jan 24, 2003 01:58 AM
