help identify this bolt
Old Jul 31, 2005 | 03:06 PM
98_gsrteg's Avatar
Default help identify this bolt
hey guys got a bit of a concern right now. I was driving today when all of a sudden I heard and felt something come off the front of my car. I actually kind of felt it on the bottom of my seat too. I stopped the car and went to see if I could find something and this bolt was lying right on the road.
The car doesn't seem to drive any differently or make any strange noises but I was hoping any of you could identify where it might of come from. I'm pretty sure its from the driver side since I felt something when the bolt fell off.
I have a 98 GSR with all options btw.
Old Jul 31, 2005 | 03:07 PM
gaydm.accord's Avatar
if its a size ten i think its one of the bolts for the timing belt covers... im gonna go with the top half of the cover
Old Jul 31, 2005 | 03:17 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: (gaydm.accord)
That's what it looks like to me too, a bolt from the black plastic timing belt cover. There are two of them, I believe.
If it is then you can simply reinstall it and tighten it down. They don't do anything other than keep the cover in place so it won't effect the engine or anything until you can find the time to reinstall it.
Old Jul 31, 2005 | 03:20 PM
Stewie's Avatar
Default Re: (Gee3)
me agree, too. The top timing belt cover bolt. Never seen a bolt like that on the entire engine other than there
Old Jul 31, 2005 | 03:22 PM
projectTeG's Avatar
arent those bolts short?....maybe check the braket for the intake manifold thats on the back of the motor.....those bolt have short threads and a extension so you can get to it
Old Jul 31, 2005 | 03:23 PM
94integragsr's Avatar
Banned
Default Re: (Stewie)
looks to me one of them bolts that go through the spring to connect your converter to your header
Old Jul 31, 2005 | 04:06 PM
Stewie's Avatar
Default Re: (94integragsr)
I wouldn't be surprised that your had your timing belt changed and when someone was putting the cover on, they stripped the bolt. The torque spec on that bolt is 86 in/lbs
Old Jul 31, 2005 | 04:09 PM
projectTeG's Avatar
i really think that bolt is too long for the cover
Old Jul 31, 2005 | 04:43 PM
Racermech's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94integragsr &raquo;</TD></TR><TR><TD CLASS="quote">looks to me one of them bolts that go through the spring to connect your converter to your header</TD></TR></TABLE>
No, that has a built waser type thing. Could you provide some measurments?? What size head, how long is it how long are the thread...etc
Old Jul 31, 2005 | 05:24 PM
apok's Avatar
Default Re: (Racermech)
Just looked at my parts, and it appears that everyone was correct. It is one of the two bolts for the upper timing cover. It connects the outer piece to the engine block. There are two holes near the drivers side engine mount. Take a 10 socket and reconnect it. Go around and tighten all of them while you're at it though.
Old Jul 31, 2005 | 05:29 PM
projectTeG's Avatar
they are that long....the ones on my engine are short
Old Jul 31, 2005 | 05:34 PM
1998IntegraLS84's Avatar
same exact thing happened to me....felt like I hit a rock and jumped up and hit me....stopped drove back and saw on the floor a similar bolt....but why would that cause a big sound under my seat?...car still drives nice which is why I didn't pay much attention to it....by the way that was over several months ago and nothings happened...
Old Jul 31, 2005 | 06:40 PM
one of the bolt IS that long. the one that connects to the front and the back of the cover.if it were short what would be holding the two top covers together. let me try and get a diagram i know for sure one is longer than the rest.
edit: number 18 maybe this is off an si though
Old Aug 1, 2005 | 10:58 AM
98_gsrteg's Avatar
guys thanks so much fro all your help. Most of you were right it is one of the timing belt cover bolts. I was very surprised to see how long the bolt is just to hold in that cover. Once again appreciate all the help.
Old Aug 1, 2005 | 11:02 AM
projectTeG's Avatar
oh....that one, forgot that one was that long
windnsalsa
Apr 4, 2018 07:47 PM
JDMarkLangston
12
Mar 13, 2013 10:08 PM
MGX
Sep 5, 2011 12:42 PM
dephtone
Dec 1, 2008 06:59 AM
BROKE.eg
17
Nov 25, 2005 08:19 PM
