d16y7 w/50shot compression results
Just tested the compression on my 97 d16y7
# 2,3,& 4 were 155~160 but #1 was 130...
I put a little oil and checked again and it was the same. 5 tries, all 130~133ish
I have ran about 2 1/5 bottles w/ the 50 shot nossle. fuel pressure was bumped up about 5 psi @ idle before adding the NOS kit.
How bad is this?
Is #1 notorious for going lean due to the poor design of the d16y7 intake mani?
How bad is this?
If the comp didn't come up with oil in the cyl your problem is North of the rings. Most likely a valve sealing issue and most likely not nitrous related unless you ran the poor thing *** lean and cooked an exhaust valve a lil.
I only put about 1/2 a teaspoon of 20w in... I've never done a valve job on the motor either.
are the numbers low for the rest of the cylindars?
I'm supprised that my 8:5:1 comp 2jz has about the same compression as the 3 good cyls' in my honda
I don't have too much Honda experience but most of the DOHC engines I have worked on squeeze out between 180-210. Some of the oddballs like the GM Quad Four will squeeze as high as 240.
The 155-160 does seem a bit low. How many miles are on this thing? Did you do the test after running it while it was warm?
Tested while warm 90 deg out w/ 100 % humidity Was at WOT, w/ 15 amp igintion fuse pulled, all plugs removed, 5 cranks per cyl. went up to like 8 trying to squeeze a few more out of #1. like 104kmi I belive on the odo. I've only sprayed like 23lbs of n20 through the setup over 30kmi.
Somthing may be up w/ the guage as the high 155's is all my supra and the civic have produced. but numerous attempts, cleaned around where it threaded in, put a bead of oil around the gasget on the comp checks threaded bit..
Any info appreciated! Thanks in advance
-James
-James
Compression tests can often be misleading. They do provide useful info but take it for what it is. The best way to determine sealing problems is by doing a leakdown test on all 4 holes.
It sounds like you did your comp test right so like I said before, i'd put my money on a valve sealing problem in that hole.
considering compression on a single cam will yeild low numbers anyway. compression is only around 9 something and the motor is not very new...
Haccordclub
May 21, 2007 08:08 AM
Jet Black
12
Jun 8, 2004 08:05 PM
