h22a4 good spot to mount external coil?
Im swapping a h22a4 into a 93 si, and ill be using the distributor off of the h23. The h22a4 did not come with a distributor, but i think it was a internal coil one. I cant find a spot to bolt up the external coil, the vtec solenoid is where it was mounted on the h23. Has anyone done this and can recommend a good spot to mount it short of fabricating a custom mounting plate for it?
