Which spark plug wires for a jdm D15b????
Old Jul 31, 2005 | 03:28 AM
EF8 JUNKIE9's Avatar
Default Which spark plug wires for a jdm D15b????
Almost done with the swap just need a few more things like which spark plug wires do i use. Which ones do i exactly need to use to fit?? i've searched but only came up with one post and didnt help much.
Need you're help ASAP!
THANKS
Old Jul 31, 2005 | 03:38 AM
RA122324's Avatar
I did that same into my 89 DX last year. I went to AutoZone thinking they would be able to look it up by engine model. Not a chance. I ended up being able to reuse the ones that were on the old engine. I had to cut a little piece of rubber off the boots but they fit. I found out afterwards that I could have just seperated the top piece from the stem itself but o' well. In case your wondering the original engine was a D15B2 in a '89 CRX DX. Automatic at that!
Old Jul 31, 2005 | 04:04 AM
d15civ's Avatar
Default Re: (knwldge54)
im using ngk plugs for a z6. they seem to fit fine.
Old Jul 31, 2005 | 04:09 AM
chris_m's Avatar
* B A N N E D *
Default Re: (d15civ)
d16z6
Old Jul 31, 2005 | 09:45 AM
Crx Jimmy's Avatar
Default Re: (Christopher M)
just take a plug out of the motor you have and buy the same ones, most of the imported motors still have ngk's in them or denso's any autozone should be able to get them
Old Jul 31, 2005 | 02:01 PM
Default Re: Which spark plug wires for a jdm D15b???? (EF8 JUNKIE9)
will a 92-95 vx work?
Old Jul 31, 2005 | 06:42 PM
bamp
Old Jul 31, 2005 | 09:24 PM
chris_m's Avatar
* B A N N E D *
d16z6 used them forever its the right ones
Old Jul 31, 2005 | 11:04 PM
Default Re: Which spark plug wires for a jdm D15b???? (Christopher M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Christopher M &raquo;</TD></TR><TR><TD CLASS="quote">d16z6 used them forever its the right ones</TD></TR></TABLE>
got em thanks!
Old Jul 31, 2005 | 11:07 PM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8 JUNKIE9 &raquo;</TD></TR><TR><TD CLASS="quote">will a 92-95 vx work?</TD></TR></TABLE>
yes
lv6l
Feb 22, 2019 11:55 AM
macmac89
Nov 6, 2010 11:36 AM
eglover20
Oct 16, 2009 10:47 PM
danmej1
Sep 23, 2009 12:55 PM
Blue_Si03
Feb 22, 2003 09:07 PM
