Torque Wrenches : In-lbs ever needed?
Old Jul 31, 2005 | 12:15 AM
miksew's Avatar
Default Torque Wrenches : In-lbs ever needed?
I have a ft-lbs torque wrench already and I'm wondering if I will ever need to add an in-lbs torque wrench to my tool collection.
Are in-lbs ever needed on Honda's? Where?
Old Jul 31, 2005 | 07:04 AM
bosco500's Avatar
Default Re: Torque Wrenches : In-lbs ever needed? (miksew)
There are many places you will need one, if you are working on your car. Especially on the motor. (oil pan, oil sump, oil pickup, piston oil squirters, cam covers... just to name a few) I bought a craftsman at Sears for around $79, and its very good quality.
Old Jul 31, 2005 | 08:41 AM
Chiovnidca's Avatar
Default Re: Torque Wrenches : In-lbs ever needed? (bosco500)
They come in handy for setting bearing preload.
Old Jul 31, 2005 | 07:57 PM
THEUSED's Avatar
Default Re: Torque Wrenches : In-lbs ever needed? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bosco500 &raquo;</TD></TR><TR><TD CLASS="quote">There are many places you will need one, if you are working on your car. Especially on the motor. (oil pan, oil sump, oil pickup, piston oil squirters, cam covers... just to name a few) I bought a craftsman at Sears for around $79, and its very good quality. </TD></TR></TABLE>
All of the things you listed are are in ft-lbs
Old Jul 31, 2005 | 09:48 PM
RedlinedVTEC's Avatar
Get a GOOD 3/8" torque wrench with a range from 0-100 ft/lb and you'll be set. You really don't need an in/lb wrench.
Old Jul 31, 2005 | 10:36 PM
Mike K's Avatar
Default Re: Torque Wrenches : In-lbs ever needed? (RedlinedVTEC)
what redlined said. my snap-on 3/8" does 0-00ft/lb ACCURATELY. unlike my friend's craftsman.
how do i know? oh, the last time i was at the honda training facility in portland, i used the torque wrench tester. set at 50lbs, my snap-on was actually 51 according to honda's gauge. the craftsman was actually at 58lbs. yea. lol.
just get a good torque wrench. and craftsman does NOT count. i'd say the lowest i'd go would be S-K. **** a craftsman.
Old Aug 1, 2005 | 12:00 AM
fkncivic's Avatar
Default Re: Torque Wrenches : In-lbs ever needed? (Mike K)
i just did an engine rebuild going off of helms torque specs and i used in lbs alot, just get an electronic one that has all of the settings lol my friend has a snap on one lol like 300 bux but worth it
Old Aug 1, 2005 | 12:51 AM
bosco500's Avatar
Default Re: Torque Wrenches : In-lbs ever needed? (fkncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">All of the things you listed are are in ft-lbs </TD></TR></TABLE>
Correct, but they are all 10 ft-lbs or under. Most 3/8 tourque wrenches will not go that low accurately. There are exceptions, But I choose to use an in/lb wrench to be more accurate.
And there is nothing wrong with a Craftsman torque wrench. Yes, Snap-On is better, but for someone on a budget that needs a good wrench, Craftsman is a good buy.
Old Aug 1, 2005 | 11:43 AM
1fastVX's Avatar
Mike K...which Snap-On Torque wrench do you have? Most Torgue wrenches has a sweet spot as far as accuracy goes. Even the Snap-On units suffer from this. On the high and low end of the measurement scales they can be off by a good percentage.
John
Old Aug 1, 2005 | 04:57 PM
new2novas's Avatar
Default Re: Torque Wrenches : In-lbs ever needed? (1fastVX)
if your gonna get an in/lb wrench get a dial type so it will be easy to do rotational torque as Chiovnidca said, for bearing preload and the like
Lauj87
Apr 4, 2007 07:50 PM
Fook_me_honda
Oct 15, 2006 10:10 PM
D16y8_619
Sep 8, 2006 09:05 PM
G-bonic
Sep 29, 2004 12:20 PM
ELAMINT5
Jun 21, 2004 03:04 PM
