Turbo car tuners: Ignition question
Old Jul 30, 2005 | 09:30 PM
Phoenix1's Avatar
Default Turbo car tuners: Ignition question
On cars making 300 plus horsepower, what total ignition timing advance do you have a redline?
Old Jul 30, 2005 | 09:32 PM
SOHC_MShue's Avatar
Default Re: Turbo car tuners: Ignition question (BlackPhoenix)
10000 degrees
Old Jul 30, 2005 | 09:35 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Turbo car tuners: Ignition question (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">10000 degrees</TD></TR></TABLE>
Thats it?
Old Jul 30, 2005 | 09:38 PM
JDMs1eeper's Avatar
Matt, you shouldnt drink and then post on H-T ... LoL!!
SOHC_MShue's Avatar
Default Re: Turbo car tuners: Ignition question (JDM S1eeper)
fo sheezy i be drunk as da neezy running 10000000000 degrees timing on my yneezy. Fo sho
Old Jul 30, 2005 | 09:51 PM
Phoenix1's Avatar
Holy ****, and I thought 40 degrees was to much!!!
Should I try 39
Old Jul 30, 2005 | 09:54 PM
93turbo16's Avatar
Always depends on the motor and the ammount of boost, compression and gas. The question is to vague.
SOHC_MShue's Avatar
nah you won't make any mad vtek power at 39 degrees. 100000 is where its at yO!
Old Jul 30, 2005 | 09:59 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Always depends on the motor and the ammount of boost, compression and gas. The question is to vague.</TD></TR></TABLE>
big factor there COMP and PSI is what will tell the total timing at full boost
Old Jul 31, 2005 | 08:37 AM
DRAGLS's Avatar
Default Re: (Snoflake)
LS 429hp 18*
Old Jul 31, 2005 | 08:41 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (DRAGLS)
d16y8 492whp 18* as well.
Old Jul 31, 2005 | 03:08 PM
Phoenix1's Avatar
Thank you DRAGLS and Hella_JDM, those were the kind of short answers I'm looking for...
Old Aug 1, 2005 | 09:39 AM
Phoenix1's Avatar
Bump...anyone else care to share?
Old Aug 1, 2005 | 10:46 AM
blundar's Avatar
If you're running flat timing you're missing out on a lot of power.
Old Aug 1, 2005 | 01:58 PM
DRAGLS's Avatar
Default Re: (blundar)
He asked at a specific point!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackPhoenix &raquo;</TD></TR><TR><TD CLASS="quote">at redline?</TD></TR></TABLE>
Old Aug 1, 2005 | 09:51 PM
Phoenix1's Avatar
Again, thanks DRAGLS. I know I'm asking a pretty vague question, but I'm trying to determine optimum ingition advance before I get to intalling an EGT gauge and a knock sensor on my LS block.
Anyone with EGT gauges, what temps are you running at the end of a quarter mile?
Old Aug 1, 2005 | 09:57 PM
blundar's Avatar
my comment was based on the numbers people were throwing out there. They were comparable to what I'd run for timing at peak torque, NOT at redline.
Old Aug 1, 2005 | 10:02 PM
SOHC_MShue's Avatar
what you don't think my number of 100000* total timing is alright blundar?
Old Aug 1, 2005 | 10:03 PM
blundar's Avatar
heh.
Old Aug 2, 2005 | 06:35 AM
blundar's Avatar
On a serious note, if you want an example of what I'm talking about with regards to timing, take a look at the dyno graph in this thread https://honda-tech.com/zerothread?id=1289876
The car is running 23 degrees timing@ torque peak @11psi. The car is running a whole hell of a lot more timing at redline. You look at the torque curve er line and be the judge.
Old Aug 2, 2005 | 07:49 AM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">On a serious note, if you want an example of what I'm talking about with regards to timing, take a look at the dyno graph in this thread https://honda-tech.com/zerothread?id=1289876
The car is running 23 degrees timing@ torque peak @11psi. The car is running a whole hell of a lot more timing at redline. You look at the torque curve er line and be the judge.</TD></TR></TABLE>
Old Aug 2, 2005 | 08:59 AM
SOHC_MShue's Avatar
Flat curve
Old Aug 2, 2005 | 10:00 AM
blundar's Avatar
I'd get flamed and/or stoned if I were to actually say how much "total timing" I run at 8500 RPM... The bandwagon would hit me and then reverse to run me over again...
And guess what... the car runs great.
ALLmotorTYPES
24
Jul 7, 2007 08:31 AM
done
Apr 6, 2005 03:59 PM
platinum00
Dec 17, 2004 08:53 AM
SleepyHF
Mar 23, 2004 05:46 PM
DRAGLS
Jan 11, 2004 05:19 PM
