Turbo car tuners: Ignition question
Re: Turbo car tuners: Ignition question (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">10000 degrees</TD></TR></TABLE>
Thats it?
Thats it?
Matt, you shouldnt drink and then post on H-T ... LoL!!
Holy ****, and I thought 40 degrees was to much!!!
Should I try 39
Should I try 39
Munkyw3rkz.webs.com
1 Post
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">Always depends on the motor and the ammount of boost, compression and gas. The question is to vague.</TD></TR></TABLE>
big factor there COMP and PSI is what will tell the total timing at full boost
Re: (blundar)
He asked at a specific point!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackPhoenix »</TD></TR><TR><TD CLASS="quote">at redline?</TD></TR></TABLE>
Again, thanks DRAGLS. I know I'm asking a pretty vague question, but I'm trying to determine optimum ingition advance before I get to intalling an EGT gauge and a knock sensor on my LS block.
Anyone with EGT gauges, what temps are you running at the end of a quarter mile?
On a serious note, if you want an example of what I'm talking about with regards to timing, take a look at the dyno graph in this thread https://honda-tech.com/zerothread?id=1289876
The car is running 23 degrees timing@ torque peak @11psi. The car is running a whole hell of a lot more timing at redline. You look at the torque curve er line and be the judge.
Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar »</TD></TR><TR><TD CLASS="quote">On a serious note, if you want an example of what I'm talking about with regards to timing, take a look at the dyno graph in this thread https://honda-tech.com/zerothread?id=1289876
The car is running 23 degrees timing@ torque peak @11psi. The car is running a whole hell of a lot more timing at redline. You look at the torque curve er line and be the judge.</TD></TR></TABLE>
Re: (blundar)
Flat curve
Flat curve
I'd get flamed and/or stoned if I were to actually say how much "total timing" I run at 8500 RPM... The bandwagon would hit me and then reverse to run me over again...
And guess what... the car runs great.
