manual trans problem? reverse
Old Jul 30, 2005 | 09:28 PM
suspendedHatch's Avatar
Default manual trans problem? reverse
I'm new to manual trannys. Anyway, I got this car, sometimes when I'm going in reverse, I put the clutch all the way to the floor, I can still hear that whirr noise Honda's make in reverse. I thought if the clutch is all the way down, in it's not in reverse. In neutral it shouldn't be making that noise. Also if I put it in first at that time with the clutch still in, it makes some crunching sounds. Supposedly this car has a new clutch. Do I need to adjust the clutch cable or anything? (90 hatch Si)
Old Aug 1, 2005 | 11:20 PM
sporkcrx's Avatar
Default Re: manual trans problem? reverse (suspendedHatch)
The whirring sound is from dog gears, the reverse gears aren't slanted like the forward gears which don't produce noise. I would adjust the clutch cable so that it grabs somewhere in the middle. If it's grabbing too far down then it might not be disengaging the clutch all the way which will cause it to grind gears.
Ludeology
Feb 15, 2008 02:24 PM
lmike6453
Sep 4, 2007 10:33 AM
EJ8VTEC
18
Jul 1, 2005 12:30 PM
p1driftfiend
Dec 30, 2003 07:34 AM
