Forged pistons, eagle rods w/Stock sleeve???
Old Jul 30, 2005 | 09:00 PM
DC-4-Drew's Avatar
Default Forged pistons, eagle rods w/Stock sleeve???
Thnks
Modified by LSvtec delsol at 10:56 PM 7/31/2005
Old Jul 30, 2005 | 09:21 PM
DC-4-Drew's Avatar
Default Re: Forged pistons, eagle rods w/Stock sleeve??? (LSvtec delsol)
b
Old Jul 30, 2005 | 09:22 PM
red-eg6's Avatar
id think it would be ok but im not 100% sure.
Old Jul 30, 2005 | 11:55 PM
FERIOkid's Avatar
Default Re: Forged pistons, eagle rods w/Stock sleeve??? (red-eg6)
why wouldn't it, just let your car warm up before you start driving to let the pistons expand correctly
Old Jul 31, 2005 | 01:05 AM
solfood's Avatar
if u want, get a block guard... its only like 90 bucks and it'll stiffen up the walls a lot better...
Old Jul 31, 2005 | 05:43 AM
DC-4-Drew's Avatar
Default Re: Forged pistons, eagle rods w/Stock sleeve??? (solfood)
The reason I ask is becuase I read on several threads that the forged piston would beat up the cyl walls because of looser clearences. It don't make scense to me but I just wanted to make sure......
Old Jul 31, 2005 | 06:37 AM
pdiggitydogg's Avatar
Yes, of course you can.
You do need to expand the wall clearance, just slightly - ie wiseco is .003"
Old Jul 31, 2005 | 07:20 AM
rmcdaniels's Avatar
Default Re: Forged pistons, eagle rods w/Stock sleeve??? (slowdx9585)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 &raquo;</TD></TR><TR><TD CLASS="quote">why wouldn't it, just let your car warm up before you start driving to let the pistons expand correctly</TD></TR></TABLE>
I think that's the answer, after the engine warms up the clearances should be the same as cast pistons. Just don't flog on it until it is warmed up.
Old Jul 31, 2005 | 02:06 PM
FERIOkid's Avatar
Default Re: Forged pistons, eagle rods w/Stock sleeve??? (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">
I think that's the answer, after the engine warms up the clearances should be the same as cast pistons. Just don't flog on it until it is warmed up.</TD></TR></TABLE>
correct. Piston slap does sound like **** and you will know when it goes away, sounds almost like valve tick just a lil bit louder. It does **** you off but you learn to deal with it for the couple minutes its there and you realize mmmmmmm i have forged pistons
Old Jul 31, 2005 | 04:51 PM
DC-4-Drew's Avatar
Kick ***, Thanks guys...
Old Jul 31, 2005 | 05:24 PM
saleensolution's Avatar
you can use it and you will not have any problems. i ran mine that way for 3 years no problem. hell theres people in the area running 20 psi still on stock sleeves with forged pistons
killerB16A
12
Mar 6, 2007 09:44 AM
PickleTeg
Apr 4, 2006 07:59 PM
95civic_b20turbo
Jul 16, 2005 11:08 AM
mrx
Sep 10, 2004 12:22 PM
hatchy
Aug 19, 2002 09:16 AM
