b18c5 swap not passing emissions
Old Jul 30, 2005 | 06:36 PM
krskrypto23's Avatar
Default b18c5 swap not passing emissions
here's the deal..
i have a kenji chipped p28 and did not pass the first emissions... i clipped J1 like i was supposed to and now my readings are backwards.. something is wrong with this pictures.. .take a look: anyone know? any help???
First reading:
HC ppm: 100/322 FAIL 97/322 FAIL
CO %: 0.56/6.21 FAIL 0.54/6.01 FAIL
NO ppm: 828/350 PASS 749/495 PASS
After clipping J1
Second reading:
HC ppm: 100/55 PASS 97/75 PASS
CO %: 0.56/0.00 PASS 0.54/0.02 PASS
NO ppm: 828/3828 FAIL 749/3870 FAIL
Old Jul 30, 2005 | 08:38 PM
Default Re: b18c5 swap not passing emissions (krskrypto23)
bump
Old Jul 31, 2005 | 03:22 PM
Educator's Avatar
Kenji-chipped p28s run VERY rich. Do you have a VAFC? If you do lean the mixture for partial throttle. If you don't then I would run the stock ecu.
Old Jul 31, 2005 | 05:15 PM
v4lu3s's Avatar
RTFM
first reading is WAY rich with good timing.
second reading is lean and good for emissions, but appears to ahve super advanced timing.
Old Jul 31, 2005 | 06:15 PM
Default Re: (v4lu3s)
the thing is that i didn't mess with the timing after i clipped J1 on the ecu... will that happen or is it a result of a bad cat? how much do i have to advance or retard the timing? thanks.. really appreciate it!
Old Jul 31, 2005 | 07:01 PM
v4lu3s's Avatar
RTFM
j1 is what determines if its running of the new chip or the original program. so you tried to pass emissions with a race program then you tried to pass emissions with the stock p28 program for a d16z6.....you need to get a chip that is designed for your engine AND emissions.
_ijayyy
Jul 4, 2012 01:49 AM
4drteg916
Jul 29, 2007 04:36 AM
GsR-Freak
Apr 1, 2005 11:37 PM
vile10
13
Nov 8, 2004 09:17 PM
ITR#00-1077
May 21, 2002 01:03 PM
