help..... anyone knows AEM cold intake 21-412 (type-r 97-01) can be used to 94-01 LS or not?
Old Jul 30, 2005 | 11:08 AM
tkycgo's Avatar
Default updated: help..... anyone knows AEM cold intake 21-412 (integra type-r 97-01) can be used to 94-01 L
I have 21-412 (integra type-r 97-01) AEM cold air intake, can I install it to my 95 LS B18B1?
It seems that is ok, but actually I know for LS part should be no. 21-403
HELP!!!!!
Aug 1, 2005
I have already installed type-r intake to LS integra, It's ok but this is not prefect fit.
the pipe is a little bit shorter than original LS aem cold intake(21-403). so the pipe is too closed with engine manifold and distributor and also the filter is too closed with the wheel's fender inner.
I decide to move out and sold it (very lucky), and already bought a used intake 21-403, it helps me to know what's big difference with 21-412 and 21-403.
In my opinion, every style intake if you buy a used, please make sure the model number first and it is better with no modification work for installation.
finally, I don't know how to post the pics so I can't let you know what's difference.
Thanks for the professional information.
Modified by tkycgo at 1:20 AM 8/2/2005
Modified by tkycgo at 1:21 AM 8/2/2005
Old Jul 30, 2005 | 11:14 AM
.one lane's Avatar
.likes trains
Hmm I don't believe you can without any modification. The intake manifold on b18c's (more lower) are different from the b18b's
Old Jul 30, 2005 | 11:17 AM
tkycgo's Avatar
Default Re: help..... anyone knows AEM cold intake 21-412 (integra type-r 97-01) can be used to 94-01 LS or
Thanks for your information........ It is used parts....... let me think what's meaning of intake manifold more lower, because I am not clear about the difference with B18C and B18B.
And also I haven't got any instruction...... Help....thanks
Old Jul 30, 2005 | 11:21 AM
projectTeG's Avatar
you want to use a dc2R intake on a dc4 right?....then yes you can
Old Jul 30, 2005 | 11:24 AM
tkycgo's Avatar
Default Re: (projectTeG)
I am so careless because I haven't check with item no. then I bought it......
It seems fit style to my car DB8 LS...... I scare it's not fit... so want to ask your professional information.
Thanks
Old Jul 30, 2005 | 12:01 PM
LSvtec03's Avatar
Default Re: (tkycgo)
yes, it will fit.
Old Jul 30, 2005 | 12:05 PM
tkycgo's Avatar
Default Re: (LSvtec03)
oh~~~ thanks thanks thanks
there are 2 guys ask me that it is fit.
Modified by tkycgo at 1:24 PM 7/30/2005
Old Jul 30, 2005 | 03:29 PM
ernald711's Avatar
yes the ITR AEM intake will fit the LS motor. you might wanna get urself a tappered couplin since the intake is a 3" and standard LS is 2 1/4. BTW all stock B series intake manifold t/b sit the same height, except for the GSR (b18c1) note that the there is a difference in the b18c's (like the GSR's c1 and the ITR's c5) and not just the b18b's. someone else explain this to him, but yes you intake will fit.
Old Jul 30, 2005 | 03:59 PM
.one lane's Avatar
.likes trains
Default Re: (ernald711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 &raquo;</TD></TR><TR><TD CLASS="quote">yes the ITR AEM intake will fit the LS motor. you might wanna get urself a tappered couplin since the intake is a 3" and standard LS is 2 1/4. BTW all stock B series intake manifold t/b sit the same height, except for the GSR (b18c1) note that the there is a difference in the b18c's (like the GSR's c1 and the ITR's c5) and not just the b18b's. someone else explain this to him, but yes you intake will fit. </TD></TR></TABLE>
Ahhh! ok! Well i was just going off memory when i was looking inside the engine bay of my friend's gsr. His intake manifold looks like a shell type deal, thought the b18c5 was the same. thanks for clearing that up for me
Old Jul 30, 2005 | 08:14 PM
blacK_Dc4's Avatar
Default Re: (Coordinator)
the type r 's intake will fit in a ls for sure .. jus gsr is different
Old Jul 30, 2005 | 08:47 PM
simon98h22's Avatar
Default Re: (blacK_Dc4)
Diameter is same on AEM for ITR as AEM on LS?
Old Aug 1, 2005 | 02:22 PM
White98LS's Avatar
Default Re: (simon98h22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simon98h22 &raquo;</TD></TR><TR><TD CLASS="quote">Diameter is same on AEM for ITR as AEM on LS?</TD></TR></TABLE>
LS is a tiny 2.5", Type R is a bad **** 3".
barnie
Dec 4, 2008 04:10 AM
DavidTurbo
Apr 7, 2003 08:33 PM
aCuRaLsTuRbO
Jul 29, 2002 01:04 AM
RolioPolio
Mar 7, 2002 11:06 PM
