Need Quick Help! Oil pan washer size!
Old Jul 30, 2005 | 10:19 AM
c.dub's Avatar
Default Need Quick Help! Oil pan washer size!
What size of a washer goes in with the oil pan screw for a DC2 model Teg?
Old Jul 30, 2005 | 10:46 AM
EMJAY's Avatar
you mean drain bolt? i believe its 17 mm
Old Jul 30, 2005 | 10:56 AM
c.dub's Avatar
Default Re: (kb12)
Yeah, drain bolt. LOL! My friend posted this, it's his Teg. I drive a CR-X. Anyways, thanks, I'll let him know.
Old Jul 30, 2005 | 11:19 AM
LSvtec03's Avatar
Default Re: (kb12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb12 &raquo;</TD></TR><TR><TD CLASS="quote">you mean drain bolt? i believe its 17 mm</TD></TR></TABLE>
the bolt is a 17mm, but the washer is an M14.
Old Jul 30, 2005 | 02:48 PM
Padawan's Avatar
Darth ModerVader
Default Re: Need Quick Help! Oil pan washer size! (deviate_si)
Keep in mind that it's not your everyday Home Depot steel washer. It's designed to deform slightly in order to form a seal (which is why Honda recommends replacing it when changing the oil).
Old Jul 30, 2005 | 03:13 PM
ernald711's Avatar
Default Re: Need Quick Help! Oil pan washer size! (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Keep in mind that it's not your everyday Home Depot steel washer. It's designed to deform slightly in order to form a seal (which is why Honda recommends replacing it when changing the oil). </TD></TR></TABLE>
true, but who really replaces it each time... Honda also recommends changing your tranny fluid every oil change...
Old Jul 30, 2005 | 06:37 PM
LSvtec03's Avatar
Default Re: Need Quick Help! Oil pan washer size! (ernald711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 &raquo;</TD></TR><TR><TD CLASS="quote">true, but who really replaces it each time... </TD></TR></TABLE>
i do, because they give it to me for free.
Old Jul 30, 2005 | 06:40 PM
EMJAY's Avatar
^ free? y...you work there
Old Jul 30, 2005 | 06:54 PM
Padawan's Avatar
Darth ModerVader
Default Re: (kb12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb12 &raquo;</TD></TR><TR><TD CLASS="quote">^ free? y...you work there</TD></TR></TABLE>
Dealer parts departments often package the washer with the oil filter, so if you purchase an OEM Honda filter, you receive the washer for "free".
Old Jul 30, 2005 | 07:19 PM
LSvtec03's Avatar
Default Re: (Padawan)
plus they only cost like ten cents, so it's not like they'd give a **** anyway.
underbelly
Mar 10, 2008 09:41 AM
BG-Teg
Mar 15, 2007 10:00 AM
EikoU
Jun 12, 2006 08:14 PM
the.hamburglar
24
Jul 19, 2005 08:39 PM
kjohnl
Mar 5, 2005 10:45 PM
