Are ITR driveshafts compatible with Si???
Old Jul 30, 2005 | 04:59 AM
supaman111's Avatar
Default Are ITR driveshafts compatible with Si???
I have a b16a2 and bought a Type r b18c5 drive shaft, will it fit???
I thought they were the same part number.
Old Jul 30, 2005 | 06:24 AM
Jwbetley's Avatar
Default Re: Are ITR driveshafts compatible with Si??? (supaman111)
um... I think that the passanger side si the same, but the drivers side has a different intermediate shaft which used a female end shaft with integras and a male end shaft for si's.
Old Jul 30, 2005 | 07:59 AM
supaman111's Avatar
Default Re: Are ITR driveshafts compatible with Si??? (Jwbetley)
the shaft i have bought is for a UK car right hand drive and its your drivers side one (the longest shaft), i have got the complete shaft. Would it fit?? looks the same from what i can remember but unsure about dimensions.
Old Jul 30, 2005 | 09:33 PM
nighttrain33's Avatar
I know that all LHD B-Series are interchangeable, but RHD, I am not so sure. Bump for you.
-Shane
Old Jul 31, 2005 | 07:47 AM
Jwbetley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supaman111 &raquo;</TD></TR><TR><TD CLASS="quote">the shaft i have bought is for a UK car right hand drive and its your drivers side one (the longest shaft),
Ours are both the same length due to the intermediate shaft.
Old Aug 1, 2005 | 11:34 PM
supaman111's Avatar
i am gona try and bang it in tonight, fingers crossed that it fits, if not i will be getting a 15lb sledge hammer to it and winging it over the neighbours garden.
Old Aug 2, 2005 | 06:20 AM
boostedcivicsir's Avatar
Mr. Badwrench
usdm itr axles will fit, BUT jdm splines are different and will not fit the hub. basically they are a civic inner with an accord/prelude outter.
Old Aug 2, 2005 | 08:19 AM
supaman111's Avatar
Default Re: Are ITR driveshafts compatible with Si??? (boostedcivicsir)
i see, i think i should be ok then as it came off a UKDM ITR car which is very similar to USDM
Old Aug 2, 2005 | 10:00 AM
B18CR_EJ2's Avatar
Default Re: Are ITR driveshafts compatible with Si??? (nighttrain33)
no all b series axles (not driveshafts) are not interchangable.. assuming that your b16 tranny is LSD, then your axles may fit, but i doubt it still if they are LHD??????
Chenzo
Sep 30, 2014 04:13 PM
DagreenEK
Northwest (Sales)
Jan 2, 2009 07:47 PM
mixmastermatt
May 13, 2007 07:43 AM
CTL
Mar 8, 2004 07:11 AM
