Stuttering Warm Startup for 10 secs
This never happens during cold start, but when warm start up, there is about 50% chance that the engine idles at a very low rpm (maybe like 100-200 rpm) and when I give it half throttle it slowly goes up, and after about 10 seconds of revving it up, the idle is fine.
Any idea what my problem is?
I already have perfect 14.7 AFR idle when this problem does not occur or after several seconds. TUned with uberdata.
Who is Mr Robot?
sometimes uberdata wont control the obd2 iacv, if you wanted to take the time to swap over to the 4-wire ( ithink, might be 2) iacv then that problem will go away
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">sometimes uberdata wont control the obd2 iacv, if you wanted to take the time to swap over to the 4-wire ( ithink, might be 2) iacv then that problem will go away</TD></TR></TABLE>
Can you tell me more about this? Any thread about it?
sounds like a eacv(electronic air control valve) at the back of the intake manifold is not working properly, i had the same problem when i ran an automatic intake manifold and just let the eacv hang with the coolant lines connected and wire plugged in. Maybe try a different eacv or just clean it with wd40?
Who is Mr Robot?
its somewher on the ud forums, i think its stickied at the top. sometimes with certain cars it just wont work, lol. i wish i could explain in better but im dead on my feet right now, tomorrow i'll look through the ud forums
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_CRX »</TD></TR><TR><TD CLASS="quote">sounds like a eacv(electronic air control valve) at the back of the intake manifold is not working properly, i had the same problem when i ran an automatic intake manifold and just let the eacv hang with the coolant lines connected and wire plugged in. Maybe try a different eacv or just clean it with wd40?</TD></TR></TABLE>
I thought I only have IACV. Can someone give me a diagram or photo to point out which one is it on my gsr?
typeeg
Jul 3, 2004 12:36 AM
