coatings?
Old Jul 29, 2005 | 09:01 PM
murtnabila's Avatar
Default coatings?
has anybody had experience w/ a turbo motor and coated (heat) chambers, i/e ports, and pistons? How did it work out? Good/bad? If bad, what problems did you have?
Old Jul 30, 2005 | 08:29 PM
murtnabila's Avatar
Default Re: coatings? (murtnabila)
anybody?
Old Jul 31, 2005 | 09:14 AM
calicodav's Avatar
Coatings are designed to enhance performance and protect expensive components. If you are blowing and shooting gas, coating combustion chambers, valves, ports, and pistons are a neccesity. You will increase performance by containing heat of combustion in the chamber reducing oil operating temps. Using coated bearings reduces friction co-efficients also reducing temps. Coating turbo housings(int. and exh.) along with header and pipes will reduce underhood temps. Coating internal engine components is like an insurance policy.
paulzy
Feb 14, 2009 12:28 PM
5thgencivic
Dec 22, 2003 11:35 AM
FragSyndrome
Jul 25, 2003 02:41 AM
legendboy
Jun 3, 2002 03:17 PM
