Strange problem occured after installation of free flow filter (please advice me)
Today i removed the stock airfilter box and installed an open air filter.The car started and run as usual but after a while it would not idle and it would not rew past 3000rpm.After a while it suddenly gets normal again.I can then drive a while before the problem reoccurs.Of some reason the last owner had replaced the stock connector on the airmeter with single wire connectors ansd some wire splices,this made me suspicious so i cut the wires and spliced them together with a stock connector i found on a junkyard.
The splices was soldered together and isolated with crimping tubes,this was done after the battery was disconnected.I tougth i had solved the problem but after a while it happens again.This makes me wonder why.
Can anyone tell me whats going on?
Is it nessecary to adjust the airmeter after adding a open air filter?The reason why i ask are because it seems to me that the injection controll system are going into a emergensy mode or something when this happens.
Ps the airmeter are of the hot wire type.
[Modified by Davy Crockett, 11:26 PM 2/19/2002]
The only hose conected betwin the trottle body and the stock airfilterbox are the crankcase breather hose.
I removed the stock box and mounted the free flow filter directly on the air meter.
Thanx anyways
Thanx anyways
SiYouLater
10
Apr 12, 2006 09:58 PM
Yosshaa
Aug 7, 2003 09:02 PM
