wheel and axle fitting problem
Old Jul 29, 2005 | 04:58 PM
alexsracing's Avatar
Default wheel and axle fitting problem
what would need replaceing to fix this?
bad wheel
good side
Old Jul 29, 2005 | 05:01 PM
CRX7's Avatar
Default Re: wheel and axle fitting problem (alexsracing)
Uh... get your frame fixed...? Were you in an accident? Is there something wrong with the suspension mounts/bushings?
Old Jul 29, 2005 | 05:04 PM
RCautoworks's Avatar
Something is bent, crossmember, lca, steering knuckle. Something
Old Jul 29, 2005 | 05:29 PM
dr_latino999's Avatar
Default Re: wheel and axle fitting problem (90blackcrx)
Rear crossmember, $5 says it is bent/broken.
Old Aug 4, 2005 | 05:16 PM
zeroice's Avatar
Default Re: wheel and axle fitting problem (dr_latino999)
mine was the lca... looked exactly the same
Old Aug 4, 2005 | 05:19 PM
88 rex's Avatar
Default Re: wheel and axle fitting problem (zeroice)
Man, did you ever notice the car pulling towards any direction other than straight?
Old Aug 4, 2005 | 06:07 PM
Crx Jimmy's Avatar
Default Re: wheel and axle fitting problem (88 rex)
it kinda looks like the boot is also all scrunched up pull it out and estend it, there is something bent thought radius rod?, nice overspray on the wheels why didnt you dismount them when you painted then?
Old Aug 5, 2005 | 07:13 AM
lazyness, the overspray came off already, i put oil on the tires and sprayed everything. the oil lets the paint on the tires fall off
car still goes straight, just sounds like a train on the tracks from axle noise
goes cha, cha, cha, cha, cha , faster with speed
Old Aug 5, 2005 | 08:15 AM
CBURKE's Avatar
Umm dude your gonna rip that boot. Why would you drive it like that? O and next time use tape and some news paper.
CrxGrin
Jan 20, 2013 08:53 PM
ryanstev
Suspension & Brakes
Nov 13, 2007 05:24 AM
buzlink
16
Oct 18, 2007 07:41 PM
ITRDC2R
Jun 1, 2007 05:43 AM
Wheelman-CZ
Jun 2, 2006 07:36 PM
