Replacing CM flywheel friction surface?
Old Jul 29, 2005 | 10:54 AM
theo99gsr's Avatar
Default Replacing CM flywheel friction surface?
Has anyone actually done this? I know that your supposed to resurface your flywheel when ever you replace the clutch but do I really need to replace this evertime or can it last through a couple clutches?
Also CM wants $100 + shipping for a new friction surface. Does anyone know where to get one cheaper?
thanks.
Old Jul 29, 2005 | 03:15 PM
theo99gsr's Avatar
Default Re: Replacing CM flywheel friction surface? (theo99gsr)
nobody has ever done this??? what about machining the replacable friction surface??
Old Jul 29, 2005 | 05:54 PM
PrettyLude's Avatar
you can get it at lightningmotorsports.com for cheaper
Old Jul 30, 2005 | 09:13 AM
theo99gsr's Avatar
Default Re: (PrettyLude)
thanks. does anyone know if this is even necessary? I've been running the CM stage 3 kevlar disc.
Old Jul 30, 2005 | 05:42 PM
PrettyLude's Avatar
just look at the condition of it when you take it off, if its thin, replace it
Old Jul 31, 2005 | 11:44 AM
theo99gsr's Avatar
i cant go days with out my car waiting for parts to show up. thats why i'm trying to see if anyone has had experience with this flywheel before. and my budgets tight right now so i dont want to buy parts that i dont need...thanks for the advice but is there anyone that has had experience with this flywheel?
Old Jul 31, 2005 | 01:06 PM
PrettyLude's Avatar
i have the actual flywheel on my car itself
Old Jul 31, 2005 | 07:27 PM
Echo7847's Avatar
I have a Fidanza which is basically the same thing. I paid $90 + shipping for my replacement friction surface. Any of their retailers should be able to get them or you can order from clutchmasters themselves.
The kit came with 2 friction surfaces and replacement nuts and screws.
Emorales
Oct 7, 2009 07:14 AM
immalooser
Oct 18, 2005 08:08 PM
Rocks
Aug 23, 2004 12:27 PM
slooogsr
May 1, 2004 06:59 AM
MintFlavored
Apr 27, 2004 06:08 PM
