Tranny Suggestion
Old Jul 29, 2005 | 09:02 AM
Orangedragone's Avatar
Default Tranny Suggestion
Okay, so i have a 93 Del sol Si that I'm going to drop a 95 b18b into, obd1. All i need right now is a tranny. I was going to go JDM b16 cable tranny, but then i hear that driving freeway is a real pain in the *** with that tranny. (about 5000rpm, in 5th gear, while going 50-60mph) Then i'm told that cable trannys wouldn't fit into my car. (?)
So my actual question is, what kind of tranny should/can i go with? cable or hydrualic?
Old Jul 29, 2005 | 09:14 AM
B18CR_EJ2's Avatar
Default Re: Tranny Suggestion (Orangedragone)
cable tranny will fit and there isnt a benefit to a hydro so stick with that cable tranny and get a b16 lsd... all gears for good honda transmissions are really close so suck it up for highway driving... my itr did the same thing on the interstate but that just keeps it in its power range for toasting d series jokers....
Old Jul 29, 2005 | 09:19 AM
DelSolDon's Avatar
try to find a hydro tranny since your car is already set up for hydro. it will make it that much easier. and about the 5000rpm in 5th at 50-60mph, mine isn't like that. i don't think i'm at 4000rpm till about 80mph.
Old Jul 29, 2005 | 09:20 AM
Jowee's Avatar
Default Re: Tranny Suggestion (B18CR_EJ2)
Get a hydro b16 or ITR tranny.
Old Jul 29, 2005 | 09:25 AM
Default Re: Tranny Suggestion (DelSolDon)
what kind of tranny are you running?
Old Jul 29, 2005 | 09:34 AM
DelSolDon's Avatar
i have the JDM B16 tranny. your rpm's in relation to your mph will also be affected by your tire size.
Old Jul 29, 2005 | 09:51 AM
D16Z6_turbo's Avatar
Get a GSR tranny because the gear ratio is alittle shorter than the LS tranny, but it's not as short as the B16 tranny. Unless you got the dough for the ITR tranny.
Old Jul 29, 2005 | 01:09 PM
ay_dawg's Avatar
b16.
itrhatchling
Jun 22, 2006 09:01 AM
type_one1
Oct 3, 2005 04:51 AM
arielmalespin
Feb 15, 2005 08:41 PM
tncivic-dvsb
Oct 30, 2003 07:29 PM
jdmCivic925
Sep 23, 2003 10:02 PM
