ZC VS D16Z6 ! !
Old Jul 29, 2005 | 05:09 AM
CUPRA_ROY's Avatar
Default ZC VS D16Z6 ! !
hello there.:
is it possibole that the D16Z6 is stronger then th ZC engine?
im asking because we checked me and my friend a lot of time he got
a new zc engine and i got the d16z6 and im 2 cars forowd him..
both of us standart not chiped not turboed!!!!!
thanks
roy-israel
Old Jul 29, 2005 | 07:50 AM
northkai3's Avatar
Default Re: ZC VS D16Z6 ! ! (CUPRA_ROY)
what cars? also depends on whos the better driver if u friend cant drive for **** then what did u expect would happen
Old Jul 29, 2005 | 08:44 AM
CUPRA_ROY's Avatar
both of us have a hatchback esi 93
and he knows the car better then me im sure..
but its seems that the d16z6 stronger then the zc..
roy-israel
Old Jul 29, 2005 | 08:58 AM
northkai3's Avatar
Default Re: (CUPRA_ROY)
it also depends on what kind of condition ur guys engines are in rims transmissions weight? any mods
B18CR_EJ2's Avatar
Default Re: ZC VS D16Z6 ! ! (northkai3)
not only does the driver matter, as well as what kind of car the motor is in... but also the zc should have slightly more hp stock because its the jdm model of the z6 so im not sure how that supports your story.... i dont know..
Old Jul 29, 2005 | 09:00 AM
Aphelion's Avatar
tell him to take the pipe bombs and AKs out of his trunk, that should save a lot on weight (jk)
You are probably just a better driver.
Old Jul 29, 2005 | 09:02 AM
CUPRA_ROY's Avatar
Default Re: ZC VS D16Z6 ! ! (B18CR_EJ2)
yep ...
but we check a few times and his motor(zc) new only 60K on it.
my d16zc 180k on it.. both of us same car same wieght...
and he knows the car from every part.
thanks any way..
roy
Old Jul 29, 2005 | 09:57 AM
northkai3's Avatar
well sounds like u just got a better deal congrats
Old Jul 29, 2005 | 10:09 AM
snoochtodanooch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CR_EJ2 &raquo;</TD></TR><TR><TD CLASS="quote">not only does the driver matter, as well as what kind of car the motor is in... but also the zc should have slightly more hp stock because its the jdm model of the z6 so im not sure how that supports your story.... i dont know..</TD></TR></TABLE>
EDITED, SEE BELOW
Modified by snoochtodanooch at 2:33 PM 7/29/2005
Old Jul 29, 2005 | 10:13 AM
nighttrain33's Avatar
Default Re: ZC VS D16Z6 ! ! (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">
you need to stfu this is the second time you have been wrong in two threads, your spreading incorrect info.
The only thing close to a d16z6 is the D15B, which is jdm. The ZC is a dohc engine, and it is much older. </TD></TR></TABLE>
Don't be an *** unless you know the facts. Check out this thread and you will find out why. i thought the same as you until Scoundrel told me otherwise.
https://honda-tech.com/zerothread?id=1323037
-Shane
Old Jul 29, 2005 | 10:20 AM
northkai3's Avatar
Default Re: ZC VS D16Z6 ! ! (nighttrain33)
ha i have the jdm d15b with a cx tranny
Old Jul 29, 2005 | 10:22 AM
Targa250R's Avatar
be professional
You need to STFU and get your own facts straight before running your mouth to someone else.
There are several ZCs, including SOHC, DOHC, and SOHC VTEC versions. They are not all "older" either, since there were OBD-1 versions of each.
Old Jul 29, 2005 | 10:24 AM
b20_ed's Avatar
Default Re: ZC VS D16Z6 ! ! (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
You need to STFU and get your own facts straight before running your mouth to someone else.</TD></TR></TABLE>
damn, I wanted to pwned em
Old Jul 29, 2005 | 10:41 AM
Default Re: ZC VS D16Z6 ! ! (b20_EK)
My apologies. I always thought the commonly referred to ZC was the SOHC nonvtec, or the DOHC used as a swap most of the time in EF civics, crxs and such.
What some people may refer to as a ZC in this forum is generally a SOHC Vtec which I always take to be a D15B.
There is alot of confusion when it comes to this, I think that the poster needs to be more clear as to what engines he is talking about, and I need to make sure I don't just on someone else too quick.
f150harleytruck7
Dec 19, 2005 04:27 AM
Honda Crx
Nov 2, 2005 01:46 PM
EJ1_519
Mar 20, 2004 09:34 AM
