engine warming problem !!!
Old Jul 29, 2005 | 05:03 AM
CUPRA_ROY's Avatar
Default engine warming problem !!!
hello everyone.
i got a problem in my civic ESI d16z6 year 93.
when the air condishiner is in hig working and cooling the engine is warming up
and cross the middle line...
when im driving without the air consishiner the warm engine is good
what cause the problem except water...????
thanks
roy israel
Old Jul 29, 2005 | 06:08 AM
CUPRA_ROY's Avatar
bump to the top
Old Jul 29, 2005 | 08:47 AM
CUPRA_ROY's Avatar
where is all the genius?
Old Jul 29, 2005 | 08:55 AM
Street Inc's Avatar
I had the same problem.....I just dont run it now...
Old Jul 29, 2005 | 09:21 AM
Jowee's Avatar
Default Re: (Street Inc)
Check for air in the coolant.
Old Jul 29, 2005 | 09:39 AM
whitesol93's Avatar
Default Re: engine warming problem !!! (CUPRA_ROY)
Your A/C puts alot of load on the engine which generates heat. You could replace the thermostat and make sure to use a 50/50 mix of water and coolant. If it does not freeze were you live you could use 40/60 or a 30/70 mix. Water transfers heat faster than coolant. Just make sure you buy a Honda thermostat. The aftermarket ones suck.
Old Jul 29, 2005 | 09:59 AM
CUPRA_ROY's Avatar
thanks.....
my friend will check it for me we will see what the problem...
roy israel
Old Jul 29, 2005 | 10:27 AM
Fulthrotle's Avatar
If you run a/c and your aux. fan is not working your eng temp will run hotter then normal.
flood's Avatar
Default Re: (CUPRA_ROY)
Also ensure that the fan comes on, that the shrouds are all in place and that there is no blockage in front of the radiator.
NullPointer
11
Sep 10, 2020 08:59 AM
Ruy
Jan 1, 2014 05:26 PM
tech410
15
Sep 22, 2010 05:22 AM
redinferno2
Dec 2, 2004 07:01 AM
Buckshot
Oct 26, 2002 02:34 PM
