Data logging: Works in ECU control but get junk in Uberdata
Old Jul 29, 2005 | 03:15 AM
swtch7's Avatar
Default Data logging: Works in ECU control but get junk in Uberdata
Basically in ECU control just about everything works when you’re viewing the gauges.
I load uber and select the com ports and it connects but my readings are WAY off. For one it never reads boost. My vacuum gauge will read -20 and uber will read -3 or so. RPM will read 300 to 400. Actually non of the work correctly, they do fluctuate which tells me it is reading something.
I have tried new bins
Using 1.7 official
moates serial to USB converter.....
Tried on 2 laptops
Any Idea's
And before you post "you should of posted in pgmfi\uberdata forms" I rarely get a response from them, and if I do its about a 2 weeks later.
Thanks for your help
Old Jul 30, 2005 | 05:28 PM
mtber's Avatar
Default Re: Data logging: Works in ECU control but get junk in Uberdata (swtch7)
uberdata requires j12 to be in place...
make sure j12 is on your ecu
Old Jul 31, 2005 | 08:08 AM
swtch7's Avatar
Default Re: Data logging: Works in ECU control but get junk in Uberdata (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">uberdata requires j12 to be in place...
make sure j12 is on your ecu</TD></TR></TABLE>
thank you sir, this worked. you are the man!
vinuneuro
Jul 25, 2008 11:58 PM
mugencx
Sep 26, 2007 06:35 PM
OMG WTF
Feb 22, 2006 09:02 AM
tvrsir
Jul 10, 2004 01:26 AM
