need to see back of an si manifold
i need a pic of a manifold in the back to see where the pvc vavle runs to
thanks alot the reason i asked bec i have a after market intake manifold and has no hole for the pvc valve or nothing at all so i would need a pic to see where i will have to block it off
you can still use it, it goes into the breater box under the manifold, just make the hose longer and pull the pcv(P-ositive C-rankcase V-entilation not pvc thats pipe you buy at home depot)grommet off the old mani and put the pcv valve in it you can also extend that hose
ohhh ..umm after a little of thinking how it works ...i think what u mean is the 1st hoes come from the intake manifold then goes down under to the pcv then the 2nd hose to the crankcase ?
yes the lower hose runs to the crank case, i'm actually working on a cheap crank case ventalation system, they work wonders on domestic i hear so i'm gonna try one on my honda the DIY cheapo way
Enta
Jan 29, 2007 03:51 AM
crexer
Mar 19, 2005 08:27 AM
