car wont go into gear
Old Jul 28, 2005 | 04:55 PM
omg_miiiike's Avatar
Default car wont go into gear
i made a post awhile ago, thinking i spun a main bearing.. but now my friend comes over, starts my car, it's making a rod knock noise.. but when you push the clutch it.. in goes away, and but when you try to rev it WITH the clutch IN, the noise comes back.. and if you try to get it into gear.. it doesn't want to go into gear, it just grinds.. would that be my clutch that went out? and what parts would i need to replace?
The tranny is a b17 cable tranny by the way.
Modified by xbleedyourdreams at 11:17 PM 7/28/2005
Old Jul 28, 2005 | 04:59 PM
Keno20's Avatar
Default Re: car wont go into gear (xbleedyourdreams)
This is an uninformed wild stab in the dark but maybe you've stripped some teeth?
Is it just 1st gear you cant get in? or is it all gears? Sorry if thats a stupid guess but its an idea.
Old Jul 28, 2005 | 05:00 PM
Default Re: car wont go into gear (Keno20)
all gears..
Old Jul 28, 2005 | 06:10 PM
Jeezer's Avatar
what happens when you start the car in first with clutch press in?
Old Jul 28, 2005 | 06:39 PM
Default Re: (Jeezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeezer &raquo;</TD></TR><TR><TD CLASS="quote">what happens when you start the car in first with clutch press in?</TD></TR></TABLE>
not sure, didn't wanna try. my dad's car is infront of mine. lol.. lemme see if i can move my car..
Old Jul 28, 2005 | 06:50 PM
Default Re: (xbleedyourdreams)
i just put the car in first, and started it. the car moved. with the clutch in. didn't let it out because i didn't feel like driving thru my yard.. what could this possibly be?
Old Jul 28, 2005 | 07:16 PM
gsr dood's Avatar
drain ur slave cylinder it mite not be engaging all the way. also while ur at it drain the tranny fluid and put in some synchromesh or honda MTF or any 10w 40 motor oil
Old Jul 30, 2005 | 11:40 AM
ek9800's Avatar
Default Re: (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">drain ur slave cylinder it mite not be engaging all the way. also while ur at it drain the tranny fluid and put in some synchromesh or honda MTF or any 10w 40 motor oil</TD></TR></TABLE>
It's nothing of that sort...it sounds like the plate is cracked, or liek stated above some cracked teeth.
Old Jul 30, 2005 | 12:45 PM
dc2jdmteg05's Avatar
had a similar prob. probably time for new clutch and flywheel
Old Jul 30, 2005 | 12:55 PM
Default Re: (dc2jdmteg05)
praying my tranny isn't fucked, just hoping it's the clutch and flywheel.. b17 tranny's are very hard to come by for cheap
Old Jul 30, 2005 | 01:13 PM
ef_you_once_more's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2jdmteg05 &raquo;</TD></TR><TR><TD CLASS="quote">had a similar prob. probably time for new clutch and flywheel</TD></TR></TABLE>
Old Jul 30, 2005 | 09:07 PM
Default Re: car wont go into gear (2uy)
hopefully it's just the clutch, b17 trannys are rare.. i need to find someone to drop my fkn tranny because i can't do it on my own.
oramac_eg
Dec 30, 2009 10:00 AM
le0ftw
Transmission & Drivetrain
Oct 7, 2008 07:19 PM
J-g-D-s-M-r
Jul 23, 2003 08:12 AM
