NEED HELP!!!
Old Jul 23, 2003 | 02:33 AM
J-g-D-s-M-r's Avatar
Default NEED HELP!!!
here's a situation i can't figure out nor my friends. i can't get into gear. even if i try to force it in it wont go in. so i have to shut off the car, put it into gear and start it up, but when i start it the car shakes violently and stalls out. when i do get the car running and step on the clutch, the rpms don't drop. i can be in 1st gear with the clutch all the way down and the car would still be moving if i was in first gear driving off. thing is, some times the gears would go back to normal like if it has nothing wrong with it. ive flushed my clutch fluids and flushed my tranny fluid as well. still does the same. it gets really bad, then it is normal. it's un-predictable. i don't know if it is the clutch but the clutch grabs when it is back to normal. im completely out of ideas of what is wrong. need help
another note is my suspension. i have this squeeking noise on my passenger back side that won't go away. i bought new shocks and replaced my bushings. it still has the squeek. it makes the noise over every bump. this has been happening before and after my shocks and bushing. when the car is parked and i push down on it, it also makes the noise. i don't know what's wrong with that either. need help!!
Old Jul 23, 2003 | 07:58 AM
thaiphob's Avatar
Nikon!!!
Default Re: NEED HELP!!! (lDarkCloudl)
1. its your clutch. dont force it into gear or your gonna f-up your yranny. <<---i know becasue this just happened to me.
2. someone will answer this.
Old Jul 23, 2003 | 08:12 AM
maxxdout's Avatar
Default Re: NEED HELP!!! (thaiphob)
as previously stated its clutch related.
#1 how many miles are on the clutch if it isnt original?
Whats happening here is that the pressure plate isnt fully releasing the clutch disc from contact to the flywheel. This is causing the car to stall as well as shake. This could be caused by a number of things. ONe of which could be the diaphram springs on the pressure plate being bent or broken. But, reguardless, its pressure plate/clutch disenguagement related.
jrhcivak
17
Apr 11, 2012 03:55 PM
Bizzle5OH3
Transmission & Drivetrain
May 13, 2011 03:05 PM
oramac_eg
Dec 30, 2009 10:00 AM
stapldnutz
Jun 19, 2006 09:48 PM
