MPFI swap possable wrong parts?
Old Jul 28, 2005 | 03:02 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default MPFI swap possable wrong parts?
i got all the parts for the MPFI swap minus ecu and dizzy (getting those in a few days) i noticed that the manafold had a PG7 on it and the rail i got with the obd1 injectors dosent fit.
here are some pics:
this is the IM
and here is the aliment of the holes with the fuel rail on it. it's not on all the way as shown but it's allinged with the injectors in the right holes.
i also got a fuel railfrom a 90 SI but it didnt even let the injectors line up.
what am i doing wrong?
Old Jul 28, 2005 | 03:56 PM
dr_latino999's Avatar
Default Re: MPFI swap possable wrong parts? (DieMaster)
PG7 - Either a D16A1 intake manifold or a DOHC ZC intake manifold, either way, the bolt pattern is different from standard D-Series Intake Manifolds.
EDIT - I pm'ed you about MPFI parts.
Old Jul 28, 2005 | 05:41 PM
ham's Avatar
ham
thats a dohc zc manifold. it will only fit a dohc zc. you need a Dseries one, I recommend a d16y8 manifold.
Old Jul 28, 2005 | 06:34 PM
DieMaster's Avatar
do all IM's have that number? so i should look for a PM6, PS9, P28,etc IM right?
Old Jul 28, 2005 | 09:58 PM
DieMaster's Avatar
bump
Old Jul 28, 2005 | 10:15 PM
boosted_hatch_216's Avatar
pm6 would be your best bet, you could use a y8, z6 etc. but the a6 or y8 are probably your best bet. i believe ps9 is the code for the dohc zc.
Old Jul 28, 2005 | 10:37 PM
ServiceAdvisor's Avatar
I bet you its a D16a1 manifold. Look at the angle of the TB. My DOHCZC manifold was the same size, but not angled. Never seen any angled except on the D16a1.
Old Jul 29, 2005 | 03:25 AM
ham's Avatar
ham
Default Re: (DOHCZCCRXSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">I bet you its a D16a1 manifold. Look at the angle of the TB. My DOHCZC manifold was the same size, but not angled. Never seen any angled except on the D16a1.</TD></TR></TABLE>
yeah. same thing otherwise.
Old Jul 29, 2005 | 04:37 AM
mr_valentino20032000's Avatar
Default Re: (ham)
the ZC manifold i just bought reads PM-7 and has alot bigger intake runners and the body is bigger too
Old Jul 29, 2005 | 05:18 AM
Default Re: MPFI swap possable wrong parts? (boosted_hatch_216)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_hatch_216 &raquo;</TD></TR><TR><TD CLASS="quote">pm6 would be your best bet, you could use a y8, z6 etc. but the a6 or y8 are probably your best bet. </TD></TR></TABLE> Hell, I would pick the Z6 manifold any day of the week over the A6, at least it has a plenum slightly bigger then the runners and it also has the universal throttle body compatibility, oh and did I mention it was 56mm out of the box?
Old Jul 29, 2005 | 06:00 AM
liquidoblivion's Avatar
DOHC ZC is PM7, that intake is from a 1st gen teg motor d16a1. You can usually goto a junkyard and get tons of PM6 manifolds off the 88-91 CIVC/CRX SI/EX.
Old Jul 29, 2005 | 07:07 AM
Default Re: (liquidoblivion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liquidoblivion &raquo;</TD></TR><TR><TD CLASS="quote">DOHC ZC is PM7, that intake is from a 1st gen teg motor d16a1. You can usually goto a junkyard and get tons of PM6 manifolds off the 88-91 CIVC/CRX SI/EX.</TD></TR></TABLE> Maybe in SC, I know here in Central Florida they are rare as hell.
datsol94
Feb 21, 2012 03:52 PM
hondaex99
Nov 13, 2009 08:12 AM
EGprojectkdkd
Jun 12, 2007 12:13 PM
Mr.Death
Jun 11, 2004 09:01 AM
pelotudo
Mar 2, 2003 05:55 PM
