00 ITR #510, dead?
its possible it finally happened. started her up, and she stalled. turned her over again, and she would hold an idle, but very weak. not at 19-21 in vacuum like usual either. no smoke at idle, but if you give it some gas, she starts smoking. no turbo noise either. no piston slap, no valve tapping.
options that my co-workers and i have come up with:
1. timing belt jumped a tooth or two. would explain the missing.
2. piston ringlands shot. previous blocks wouldnt even idle when the ringlands went out though..
3. turbo blown. this is the one im leaning toward. the smoke that comes out smells like excess gas and oil. when i took the filter off, the cold side of the turbo wheel still moved...
fun with forced induction.
cliff notes: turbo R down for the count?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkie757 »</TD></TR><TR><TD CLASS="quote">its possible it finally happened. started her up, and she stalled. turned her over again, and she would hold an idle, but very weak. not at 19-21 in vacuum like usual either. no smoke at idle, but if you give it some gas, she starts smoking. no turbo noise either. no piston slap, no valve tapping.
cliff notes: turbo R down for the count?</TD></TR></TABLE>
do a compression test, when my stock motor went (pisont ring), it was blowing smoke out the valve cover, low compressoin on #3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">
do a compression test, when my stock motor went (pisont ring), it was blowing smoke out the valve cover, low compressoin on #3</TD></TR></TABLE>
ive blown up two b18b1's in my previous car, both were piston rings, and they made a LOT of noise..
i guess its possible though....
Modified by boostjunkie757 at 8:46 PM 7/28/2005
perfect timing dustin. buy my **** http://hondamarketplace.com/zerothread?id=1322706 and call it a day.
haha. but on a serious note, let me know if you want to build and sleeve it
-Francisco
-Francisco
My ringland was a silent failure. Lots of blowby, and eventually it sucked enough oil to foul the plug.
Look at your plugs yet?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">
Look at your plugs yet?</TD></TR></TABLE>
not yet...but i should probably tomorrow...thats scary..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cell »</TD></TR><TR><TD CLASS="quote">sorry to hear that dustin. just build the bitch and have some more fun..
remember, turbo > na.
so don't listen to the crackhead above me </TD></TR></TABLE>
and you know this......MANG!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing »</TD></TR><TR><TD CLASS="quote">perfect timing dustin. buy my **** http://hondamarketplace.com/zerothread?id=1322706 and call it a day.
-Francisco</TD></TR></TABLE>
im thinking possibly mild build.....as long as the cylinder walls arent too torn up. rods & pistons....definitely, more boost on the way..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkie757 »</TD></TR><TR><TD CLASS="quote">im thinking possibly mild build.....as long as the cylinder walls arent too torn up. rods & pistons....definitely, more boost on the way..</TD></TR></TABLE>
There's people making STUUUUUUUUUUUUPID power on stock sleeves. I'm sure you know this already.
Stay away from the block guard crap too, I wouldn't mess with it personally.
Oh well, get the plugs off, that'll give you a BIG clue what's wrong. A compression tester from NAPA or anywhere isn't too expensive either, I carry one in my toolbox.
Oh well, get the plugs off, that'll give you a BIG clue what's wrong. A compression tester from NAPA or anywhere isn't too expensive either, I carry one in my toolbox.</TD></TR></TABLE>
i work at a bmw/honda dealership...
we've got a few compression testers lying around...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RStoR »</TD></TR><TR><TD CLASS="quote">sniff-sniff
dont cry...
she was a good block.....she lasted quite some time. if id realized the boost gauge had gone bad, it wouldnt have come to such an abrupt end.
she's gonna come back to life, dont worry......MUCH quicker too...he he he..
</TD></TR></TABLE>dont cry...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RDLIN-IT »</TD></TR><TR><TD CLASS="quote">Thats sucks man. Now I'm second guessing boosting mine. </TD></TR></TABLE>
just pay attention to your boost gauge. if it doesnt read 0 when you turn off the car, its broken.
i was pushing 21 psi for about 3 months after the headgasket repair.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing »</TD></TR><TR><TD CLASS="quote">just let me know when you are ready. ill hook the rebuild up</TD></TR></TABLE>
well, we'll see what needs to be replaced in a couple days.
blowing motors is part of boosting..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RDLIN-IT »</TD></TR><TR><TD CLASS="quote">Did Shad do your hondata tuning?
yes sir.
and he'll also do the tuning when its running again.
yes sir.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">blowing motors is part of boosting.. </TD></TR></TABLE>
...a stock block on 21 PSI.
Zoinks!
-Chris
Zoinks!
-Chris
mnlude
Apr 12, 2006 04:54 PM
